Author Topic: 78' 550k returned from ashes...  (Read 2302 times)
Offline g8ts
« on: July 11, 2006, 05:29:43 PM »
Hey all,
Great site!
Little history on bike
I bought this bike 18years ago with 4k miles put a couple hundred on it then parked it.
My buddy moved to the states from Germany and wanted to learn how to ride about 8 Years ago. So me being a nice guy brought it out with a little tune she purred for about 2 years for him. He put about 10k on her. He learned how to ride and went out and bought a BMW. So he parked her for 10 more Years. Now with gas prices I thought why not and I brought her back out. I removed carb's gave them a good cleaning.
Now the questions for you experts.
1) For the 78' are the floats to be set at 12.5mm (.57in)
2) Low Idle screws (the ones under carb pointing up) 1 to 2 turns then set to highest idle.
3) Where my gas line enters carb. There is another hose connection line there. Mine is open. Should
    this have a plug on it ? what is it for ? When I spray carb. cleaner there my RPM's go up so
    does not seem right that it is open. (rain and all)
Just some new coils now (wires leaking a little) and a little carb adjust and I'm on the roll...
Honda dealer by me really stinks, either is just an *#!* or does not like the classics so I will not give him any of my money. Anyone know anything about these guy's http://legendsmc1.tripod.com/
said he would sell me coils for $88.00. I would like the plugs to be removable though.
Hey thanks for the help...
"rebuild it rebuild it and rebuild it"
quote from 30 year old Honda owners manual.
Good thing though, its good for another 30 years.
78 550 gone sent to friend in Germany
72 750 brown
73 750 Red
74 750 green
74 750 strange color extended forks
75 750 blue
75 500t sold
75 360 cl orange
77 750ss black
82 900c blue
83 650 CX black
Fence and herding dog to keep them all in.
Re: 78' 550k returned from ashes...
« Reply #1 on: July 11, 2006, 06:57:02 PM »
Yes.  For PD46C carbs.
Yes.
This is a carb float bowl vent. A tube is attached and it terminates between engine and swing arm in front of rear wheel.
Offline g8ts
« Reply #2 on: July 11, 2006, 07:12:20 PM »
Thanks Two Tired. Going to set carb. floats tomorrow and run that vent tube. I'll send you a pic...
G8ts
72 750 brown
73 750 Red
74 750 green
75 750 blue
75 500t sold
75 360 cl orange
77 750ss black
82 900c blue
83 650 CX black
Offline g8ts
« Reply #3 on: July 12, 2006, 06:48:06 PM »
Well I set the floats to 12.5 mm from bottom flange to end of float.
Started great cold 1100 rpm solid idle. After warming up lost low idle.
When I am sitting on bike and I lean bike to the left idle goes up... Hmmm thinking on setting floats to 10.5mm from end.They where at 15.5mm at this measurement location and the tweak to 12.5mm really helped performance. Not sure, reading a lot about this subject, the exact place to set measurement on floats is a little gray. I set at the end of float with bracket just resting on float pin. But in my mind if I'm not getting any over flow from the bowls I still have a little room to tweak. Can't think of anything else that would make this effect when I lean bike? What do you think ?
Other than that it ran GREAT! Just a little tweaking on the low idle and I'm good...
Thanks for the input. It's a Great site...
G8ts
72 750 brown
73 750 Red
74 750 green
75 750 blue
75 500t sold
75 360 cl orange
77 750ss black
82 900c blue
83 650 CX black
Offline 78 k550
« Reply #4 on: July 12, 2006, 09:14:08 PM »
Is that 88 with shipping? I know of them and never bought anything from them. Never got a good feeling from them years ago with my Bultaco stuff. So I never have been back. What are you looking for I can prebably get them cheaper.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #5 on: July 13, 2006, 12:04:32 AM »
This bike should need choke to start cold to make it run richer.  If they are rich to start with cold, they will be too rich when the engine warms.
The dual float arangement in each carb is supposed to prevent fuel level changes when the carbs are tilted.
I would check your throttle cables for binding.  Does the idle change when you turn the bars?
The 77 model floats were set at 14.5mm.  But, they also had slightly different jetting.
Do you still have the stock air filter and exhaust?
Have you vacuum synched the carbs?
Have you fine tuned the Idle Mixture Screws?
Offline g8ts
« Reply #6 on: July 13, 2006, 03:47:50 AM »
Thanks Paul, Looking for coils with removable plug wires. Maybe a dyna coil.
72 750 brown
73 750 Red
74 750 green
75 750 blue
75 500t sold
75 360 cl orange
77 750ss black
82 900c blue
83 650 CX black
Offline g8ts
« Reply #7 on: July 13, 2006, 04:09:13 AM »
Choke was needed to start till warm.
The dual float arrangement in each carb is supposed to prevent fuel level changes when the carbs are tilted.
Don't think so. Will have to check this one today. Can't see where it would bind, all strapped in and snug.
Yes, all stock
No, Don't have the sync. tools. I did check that they where all at the same height with a pin.
No will do today.
Thanks for the hand will check today and let you know. What do you think if I tweak the floats alittle more? With the dual floats I just don't get the Idle going up when I lean it. It definitely is gas causing the idle to go up.
72 750 brown
73 750 Red
74 750 green
75 750 blue
75 500t sold
75 360 cl orange
77 750ss black
82 900c blue
83 650 CX black
Offline g8ts
72 750 brown
73 750 Red
74 750 green
75 750 blue
75 500t sold
75 360 cl orange
77 750ss black
82 900c blue
83 650 CX black
