Author Topic: Carb Rebuild  (Read 856 times)
Offline rk
Carb Rebuild
« on: December 11, 2012, 08:50:00 AM »
Hey guys, I'm at the point now where I can start putting these things back together. I'm guessing the carbs were set for the original 400CC... now that it's been bored out, should I adjust the main jet up or down or just set the new one exactly like the old one?
The stock jet has 18234 stamped on the top of it, and the new one has D22... does the difference matter?
Also... can anyone shoot me a link to the 400F carb rebuild thread, I can't seem to find it.
Another dumb question... jet size... do I read that from the long slender piece that moves, or the small piece it mates with. If its the small piece, the old one says 90 and the new one that comes with the rebuild kit says 75... is that an issue?
Finally, this solitary 'O' ring that comes with the kit, where does it belong? I haven't figured that out.
Thanks!
Ryan
« Last Edit: December 11, 2012, 09:11:39 AM by Ryan Kurtz »
1975 CB400F (First bike - learning lots)
- Podded
- Dyna S ignition
- Yoshima Exhaust
- bored to 473cc or 466cc... or something. Maybe someone can correct me
- #82 mains, #42 pilots
Offline lucky
Re: Carb Rebuild
« Reply #1 on: December 11, 2012, 03:00:08 PM »
Thanks!
Ryan
You do not need to rejet for that small amount of increase of bore.
You may need to adjust the mixture screws just slightly.
Re: Carb Rebuild
« Reply #2 on: December 11, 2012, 09:48:50 PM »
Thanks!
Ryan
Those 75 jets are mighty small for a 400! Use the original ones, just make sure they are nice and clean.
