Author Topic: Powder coat masking  (Read 781 times)
Offline stereosilence
  • 1975 CB550K
Powder coat masking
« on: December 11, 2012, 03:49:23 PM »
What portions of the frame need to be masked? I'm thinking the threaded portions (ground point, etc). What about were the engine bolts go through the frame? Anywhere else?
Offline gonzobrian
Re: Powder coat masking
« Reply #1 on: December 11, 2012, 04:19:55 PM »
Maybe the VIN tag if you can't take it off.  They make heat resistant tape that works great to mask stuff off.  I've also used silicon plugs which also work well.
Offline brooze72
« Reply #2 on: December 11, 2012, 07:29:56 PM »
Exactly, anyplace where the thickness of the paint will cause problems reassembling, threading or grounding. Watch the swing arm pivot points.   Easier to mask than sand off later.  Are you sandblasting 1st? If so, watch out for any VIN or stickers you want to keep.
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline luap
  • LAWL
« Reply #3 on: December 13, 2012, 12:19:36 PM »
A good powder coating company will/should mask off the areas for you.
Steering Stem
All threads an tapped Areas
Disassemble the swingarm So when it goes in the oven the grease doesnt leak on the new power
Holes where the rear brake lever linkage rod mounts
IMO its just easier to grind off the powder in your grounding points areas
Motor mount IMO not so much A tap with a hammer will push the bolts through
If your doing your triple trees Tape off the inside where the bars mount
Paul
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
