Author Topic: motor cleaning  (Read 904 times)
Offline rokusek
motor cleaning
« on: December 11, 2012, 06:58:49 PM »
So I'm looking for anyone in the Indianapolis area that can clean a motor well enough that it can hold paint? I've been cleaning it myself but and getting tired of doing it the long way....or does anyone have a suggestion... :-\
Re: motor cleaning
« Reply #1 on: December 11, 2012, 07:19:05 PM »
I use the CRC Brakeclean to degrease, along with a bronze brush from an auto detailing kit. Lacquer thinner on Q-Tips gets the nooks and crannies, along with a screwdriver to pry the thicker stuff out.
If you can get it to a carwash, plug the in & out ports by covering the top end with several plastic bags, and the oil ports (if it is a 750 engine) with some duct tape, with 4 6x16 screws to hold it down when wet. Then just blast away, and use their degreaser solvent. It takes about $5 here, but in Colorado we only get 1 second per cent for our quarters because water is so expensive.  :-\
Offline rokusek
Re: motor cleaning
« Reply #2 on: December 11, 2012, 07:36:41 PM »
thanks! I actually have the motor taken apart so that should make it easier....I was looking out there to see if there is anyone that knows of a company that can just dip it in a solvent that eats away the grease or something like that...I'll give the car wash a shot
Offline 736cc
Re: motor cleaning
« Reply #3 on: December 11, 2012, 09:03:08 PM »
EZ Off oven cleaner yellow can wins the nastiest battles. S-100 is my favorite all-time for the best finish.
Offline Old Scrambler
Re: motor cleaning
« Reply #4 on: December 12, 2012, 02:46:41 PM »
De-greasing is the big problem for holding new paint................When you think its clean.........give it another shot. You may want to investigate the DIY soda blaster.............then apply acetone as a paint prep and begin painting ASAP.
I now have a 4-year old paint job on my 750 motor...........its stating to peel next to an exhaust port........I think I helped to start the process by getting too close with a power-washer nozzle while the motor was hot.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
