Author Topic: Brake pad clearance issue  (Read 3484 times)
Offline eelliiss
Re: Brake pad clearance issue
« Reply #50 on: December 14, 2012, 09:31:56 AM »
The K7-K8 piston does not have the rounded removable cap. It has a piece pressed into the pad end. The piston itself is a cup, and the bottom of the cup goes into the caliper.
Ok, even more informative.  Thanks for the info.
« Reply #51 on: December 14, 2012, 09:45:10 AM »
The end of the piston at the top in this pic faces the pad.
« Reply #52 on: December 14, 2012, 09:48:56 AM »
Once again I goof talking about later parts. I should stand down, sorry.  :(
Offline eelliiss
« Reply #53 on: December 14, 2012, 09:50:59 AM »
Bike will be on the damn road this weekend, hotdammit!
Offline eelliiss
« Reply #54 on: December 17, 2012, 07:45:53 AM »
We fixed the binding issue.  I did have the piston in upside down, but I decided to replace it anyhow.  I figure I might as well since there is more pitting on there than I'd like.  I was looking at a build thread earlier for a 74 CB550, and I noticed that the calipers are remarkably similar looking.  When I did research on sites that sell OEM parts, they actually accept the same pads, bleeder screw, and hard pipe, but they have different piston seals and possibly pistons altogether as they are still available for the 550 but not the 750.
Before I stumbled across that build thread this morning, I purchased a new piston on eBay for what I thought was the 77-78 CB750K caliper that I have.  How easily should it slide in with the caliper seal in?  I purchased a new 77-78 piston seal, and althought it seems to fit pretty snug, the old piston would not press in fully just by hand.  I used a large socket and mallet to gently tap it in.  I just want to make sure I have all the correct parts!
Pic of my caliper for reference:
