Author Topic: Yolanda 2.0 new pretty carbs  (Read 117899 times)
Offline iron_worker
Re: First Bike: Yolanda the Honda CB750 K1
« Reply #300 on: April 01, 2013, 06:53:23 PM »
Ya the dremel wire wheels aren't meant for anything that large. A brass wire wheel in a drill works great for heavy corrosion. I used one all the time for prepping stuff for zinc plating.
Great update btw. You must have spent a nice chunk of change in those carbs!  :o Should run like a dream though.
Just take the plunge like I did and get some repro pipes from CMSNL... I can't tell the repro pipes apart from factory.
IW
« Reply #301 on: April 01, 2013, 07:41:20 PM »
Have we seen the pipes up close yet? Really that bad??
Offline cheftuskey121
  • Super Newbie
« Reply #302 on: April 01, 2013, 08:50:08 PM »
It spins so much faster than a drill though, I figured it would be better. I'll go pick up a large wire wheel tomorrow and give it a Shot. My chrome covers came in from cycle x tonight and they look amazing. I hope with good care they will last a good long time!
  • Super Newbie
« Reply #303 on: April 03, 2013, 12:00:57 AM »
update time, I am so late with these things. sorry guys!
Alright time to tackle wheels!
4 nuts and 8 washers and boom
I love the look
Add to that a rear wheel!
my chromed engine covers came in from cycle x. they look fantastic! I opted out of the head because I wanted to keep my painted but I have chrome tappets to give a little detail, you'll see soon
reassembling my clutch cover, with the proper spring this time
got the stator and coil in place. colored in the black area with sharpie :D
got to work with my SS engine cover bolts. the kit I got....I would not recommend it again. I had to cut many bolts, and I didnt end up cutting the caliper bolts, I just used my old ones because they weren't that bad and it would have taken me forever to cut them with my dremel. it just be plug and play. I can't remember what site I used but if you want plug and play stay away. if you dont mind a little work then no worries!
new gaskets on with copper gasket spray on the gaskets
I just purchased a clutch adjuster cover on ebay, the chrome I have is so beat compared to the new chrome. the one I bought looks better, I really hope it is....
ey girl.
so I did not take enough detailed pictures of the fender and caliper mounting....I had to piece it together from the fiches (which are so separated its hard to get a big picture, and my own pictures, and a little thinking. I soon found out I was not going to be able to mount up the fender 100% with the wheel on. bummer. so I took the wheel off an d was able to reach the inside facing bolts of the center fender mount to the forks. then I put the wheel back on and all was well
got my shifter cover on as well. I am going to crack back in it to change out that small o-ring behind the shifter selector hub. I have to get new screws to as they look stripped out. could be fun. still waiting on my oil pump o rings as well, and I am still going to be changing out my clutch plates....need some more money. good thing I can do that later
cured the head, since it can fit in the oven, and got the new gasket on and torqued the bolts to 6.5 ft lbs *from what Ive researched that is acceptable)
well it was about 1am and I decided I wasn't done for the night. I grabbed my brother and had him come help me. it was time to put the engine in! I very quickly remember how heavy that engine was.... I put down a LOT of paper (stuff cycle x wrapped my parts in) and we laid the engine on its side. then I tried to tip the burly frame over it and it wasn't happening... too heavy and awkward with all that crap on it. took the front and rear wheels off as well as the handlebars. then we shimmied it down over.
I actually didnt even scratch any paint. grinding off those lower engine tabs really worked wonders. DO IT.
put the three long engine bolts in and tipped the bad boy up balancing on the centerstand and front forks (didnt want the fender to have weight on it). then my brother struggled to hold the whole bike up so I could get the front wheel in there. we gently set it down and olted the front wheel on proper.
before the rear wheel went back on, I took the sprocket hub off AGAIN. this is three times now. I don't know how it happened, but I misplaced one of my little plastic bins with parts, and then I found it and the only thing inside was a large spacer that said "rear wheel outer spacer" on the baggie....I'm thinking what the crap. I guess I didnt have good enough part names as I was taking it apart because it turns out its the spacer that goes between the wheel bearing and the hub bearing. so I pried off the sprocket hub yet again and set it in there. upon getting the hub back on (still a PAIN with these new dampers and it wasnt seating dwn properly) I was able to get it almost perfectly flush. it may be off .5mm in one spot. much better than before. I am hoping it cures itself since the rubber is new.
I got the rear wheel back on, and could not help but to take a little mock up picture for inspiration. I hope you enjoy it as much as I do, it really gets my heart pumping!
thanks for reading!
Offline Tews19
  • I am no
Re: First Bike: Yolanda the Honda CB750 K1 (engine and frame are ONE)
« Reply #304 on: April 03, 2013, 02:34:21 AM »
Holy #$%*! BOTM once she is done! Great work Justin.  Seriously great work!
1970 Honda CB750 survivor.
« Reply #305 on: April 03, 2013, 04:19:28 AM »
Looks fantastic, great job.  Love the look of those Conti's, how did you decide n them?
Cable holder headed your way today....
Offline Vinhead1957
« Reply #306 on: April 03, 2013, 04:39:52 AM »
I agree looks fantastic
Offline Garystratos201
  • I have never been a
« Reply #307 on: April 03, 2013, 05:34:36 AM »
Most excellant work. Also gets my vote for BOTM............Gary
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline iron_worker
« Reply #308 on: April 03, 2013, 07:18:00 AM »
She's gonna be a looker for sure.  8)
Those chrome covers were a great choice btw. That's probably the best solution for bling vs. maintenance.  ;D
IW
« Last Edit: April 03, 2013, 07:22:33 AM by iron_worker »
  • Super Newbie
« Reply #309 on: April 03, 2013, 07:25:53 AM »
Stev-o, I researched and those tires seemed to be the closest ones with stock patterns on them. I really love the look of the old tires. I am hoping they hold up. I don't plan on throwing her into any corners and minimal wet riding so I am not super concerned with performance. I have heard rave reviews about Avon if I ever go that route. time will truly tell with the contis when I get it up and running.
  • Super Newbie
« Reply #310 on: April 03, 2013, 07:29:35 AM »
thanks for the kind words guys! I am still stumbling through this, but last night I was teaching my little brother about how these parts work when he was asking. its such a nice feeling to show and describe how something works when I didn't even understand it 5  months ago!
IW, it was a judgement call because 73nancy said he was booked up until about the end of april for polishing. his work looks fantastic, but impatience gets the best of us sometime. I am still shootting for a mid may deadline because I want her maiden voyage to be 5 hours away (by car) to a concert with my buddy on his bike. I honestly couldn't wait that long for the polishing, and chrome is going to be a little easier maintenance to retain brilliance. cycle x's chrome exchange was just too enticing. polish and patina for another bike ;)
« Reply #311 on: April 03, 2013, 08:08:48 AM »
Seriously impressive.
Offline bender01
« Reply #312 on: April 03, 2013, 08:38:22 AM »
Wow . Ive got to get down and see that thing.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Mo
« Reply #313 on: April 03, 2013, 08:40:21 AM »
That engine looks awesome!
Offline jerry h
« Reply #314 on: April 03, 2013, 09:23:55 AM »
Looking good!  Having fun watching your progress.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #315 on: April 03, 2013, 09:30:58 AM »
Looking fantastic Chef! Seeing it looking like an actual motorcycle and not just a bunch of parts is great motivation for the push to complete. When it's done you will have something that the guys that just walk into a showroom or an auction and plop down big money for a new or fully restored bike will never experience, the satisfaction and pride in knowing that YOU built it. As a chef and mucisian I imagine you already understand that feeling to some extent already.
I am looking forward to the final product and reading about your first ride.
Offline curemode2002
« Reply #316 on: April 03, 2013, 10:59:36 AM »
Wow! The bike is looking awesome.
Bikes:
1980 CB650 Sold
2015 Monster 821 Stripe
Offline Roach Carver
« Reply #317 on: April 03, 2013, 12:07:35 PM »
three thumbs up.
wait that sounds weird.
« Reply #318 on: April 03, 2013, 03:00:19 PM »
Nice work...
  • Super Newbie
« Reply #319 on: April 03, 2013, 05:49:22 PM »
IW
IW I really want to but I won't be able
To afford it until after summer probably. Good thing is they are an easy replacement ;)
  • Super Newbie
« Reply #320 on: April 03, 2013, 05:50:40 PM »
I don't think I've taken a picture. I'll do that tonight and put it in my update. It's
Enough to make me cringe.
  • Super Newbie
« Reply #321 on: April 03, 2013, 05:52:01 PM »
Thanks for all of the kind words and encouragement guys. This is such a fulfilling project :)
Offline Mo
« Reply #322 on: April 03, 2013, 06:53:55 PM »
Completely random, and you may have answered this previously, but is that mustache a permanent fixture, or is it to enhance the bike's appeal?  :P
Offline Inkswitch
« Reply #323 on: April 03, 2013, 06:59:21 PM »
Chef, you've got me rethinking my color from candy gold to your color.  Looks fantastic!
1971 CB750K1, 1987 Buick Grand National.
  • Super Newbie
« Reply #324 on: April 03, 2013, 08:15:10 PM »
hah! I started growing it a few years ago and it just has stuck. I am happy with it. its a nice conversation piece :D
