Author Topic: Yolanda 2.0 new pretty carbs  (Read 116561 times)
Offline tweakin
  • tear down
Re: Yolanda 2.0 Moving Forward
« Reply #750 on: December 19, 2013, 08:04:22 AM »
Coming along great Chef!
Offline cheftuskey121
  • Super Newbie
« Reply #751 on: December 19, 2013, 08:28:35 AM »
new triple tree top and bottom finished!
new fork lowers painted!
Jay Ace
« Reply #752 on: December 19, 2013, 11:31:56 AM »
Looks good! She will be better, stronger, faster!
Offline iron_worker
« Reply #753 on: December 19, 2013, 12:23:18 PM »
That engine came out great. The VHT seems to have a bit more shine than the Duplicolor but they are very similar shades. I'm thinking of doing a similar thing and converting my parts washer into an oven with some insulation so I can bake my top end. lol
You're moving right along now. Glad to see everything coming back together for you.
IW
  • Super Newbie
« Reply #754 on: December 19, 2013, 05:36:42 PM »
today was paint day, my correct K1 ears are primed and painted! yay. hardest color in the world to photograph...
Offline lwahples
« Reply #755 on: December 20, 2013, 08:53:54 AM »
Ears came out nice.Good shine coming from a can.
« Reply #756 on: December 20, 2013, 09:01:49 AM »
Damn good for a rattle can!
Offline wowbagger
  • Not much of an
« Reply #757 on: December 20, 2013, 09:03:59 AM »
"Shiny" as Mal says.
« Reply #758 on: December 20, 2013, 10:46:27 AM »
Bling, bling!
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #759 on: December 20, 2013, 12:45:40 PM »
Your decision to personally paint everything as far as this bike has me really rethinking how to have my bikes painted. What you've done looks so well done I have a hard time believing it comes out of a rattlecan.
« Last Edit: December 21, 2013, 06:17:07 AM by deafcaferacer »
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
  • Super Newbie
« Reply #760 on: December 20, 2013, 04:09:49 PM »
thanks for the kind words  :) i assure you it is rattle can. spraymax 2k is magical stuff when its used right :D
I am just awaiting tapered neck bearings and its off to the races with rebuilding.
Offline tweakin
  • tear down
« Reply #761 on: December 20, 2013, 04:21:45 PM »
Looks great Chef, really like the color.  The 2K clear is great paint.  I did my CL360 in it last year, even wet sanded and buffed.
  • Super Newbie
« Reply #762 on: December 20, 2013, 04:31:16 PM »
oh hot mama that thing is gorgeous. I bet it RIPS!
Offline edhaeuser
« Reply #763 on: December 28, 2013, 08:57:11 AM »
Looks like you are making good progress, Justin!  Going to be as good as the last round!  I have been sidetracked with too many projects and my 750 is on hold for a while.
  • Super Newbie
« Reply #764 on: December 28, 2013, 10:52:44 AM »
I sure am hoping so Ed! I got the engine (75F) in the new K1 frame and got my "new" front end assembled. put a shifter on and tried to put it in gear. nothing either way, and that was with me moving the sprocket. well crap. so I popped the tranny cover and the whole shift linkage above the shift drum is missing. wow. guess it was rummaged for a few parts while it sat for so long. good thing I now have a "spare" engine. I will be taking that off the K1 engine tonight and hopefully getting it in place. last time I messed with the linkage I spent a few hours trying to get the springs loaded correctly, it was a nightmare.
I plan to get that in place tonight, then get the oil tank/hoses, wiring harness, coils/plug wires, ignition, fender, chain guard, and rear wheel on. whew. as long as I get this shift linkage done I don't forsee anything too crazy. just hoping the engine fires up and doesnt leak or smoke. crossing fingers!
in other news, I GOT the cb450 in massachusetts I was looking at, it was picked up last night and will be here in a few days. very excited about it, i will be starting another project thread in the other bikes section. anyone 450 savy chime in, I don't know anything about them
  • Super Newbie
« Reply #765 on: December 30, 2013, 12:10:40 PM »
another update. ups and downs of rebuilding. the holiday season always makes it difficult to dedicate any time to the bikes. working 60 hour weeks sucks, but, whatever.
I finally got the old front end off the old frame....thos bent forks were fun. trying to get all of the little pins and spacers off a bent fork...yeah. got all those little pieces on the new fork, new seals and into the 'new' lowers. got those mounted up to the front end. something odd though. when putting in the all balls tapered bearing kit, I found out that the top bearing was too tall creating a gap at my fork ears. I used the same bottom spacer as on my other triple so I could verify, it would appear this kit has different bearings. the old ones say KML on them and the new ones say ALL BALLS on them. odd. I was able to just use the top bearing from my old triple, and add the seal/washer on top of the stack under the stem spanning nut. in the end it worked out but its a good thing I already had that bearing from before or I would have been scratching my head. it all lines up fine on the bottom too.
here are the forks...well there's your problem
My buddy (only other guy in Savannah with a 750 I believe) came over and helped me get the 75F 'new' engine into the 'new' frame. my two rear mounting bolts were slightly cocked but they went in fine. layed the motor down and put the frame on. minimal damage and not too much fuss.
  • Super Newbie
« Reply #766 on: December 30, 2013, 12:25:08 PM »
front end on with new correct fork ears....so pretty :)
threw a shift lever on there to test the gears and nothing. up or down, moving the sprocket. it returned to center, but would not shift. I call Bill Benton, who I bought the motor from (it was a friends of his, higher mileage, pulled to put a new motor in and this one just sat indoors for awhile), and ask if he had any thoughts. he said open it up. so I popped off the tranny cover and this is what I saw
the whole shift linkage was missing! kinda irritated me, but also kinda cracked me up "well THERE's your problem!". so I transplanted it from the other engine now that I have a parts engine ;)
I remember from last time how difficult it was to get that last spring thats flush against the crankcase on there. I am fumbling with it for a good 15 minutes and my brother walks in, sits down and takes the spring and tab and gently sets it perfectly in place on his first try. I just about knocked him out for being a twit ;)  he held it in place while I put all the assembly on that long bolt and got it finished up, shifting just fine. don't mind the drum bolt....I errr....thought I should take it off and realized it wasn't coming off by natural means, so before I got medieval on it with cutting tools and drill I had some sense talked into me about LEAVING IT ALONE. funny I just read through edwardmorris's thread and he did NOT leave it alone and had it snap. glad I walked away from it. now it looks mangled but it is solid as a rock.
that brings up the next issue I faced. I was getting in gears but was able to spin the final shaft/sprocket by hand in all gears. that doesn't seem right from what I remember. called Bill again and he suggested making sure the clutch adjustment was set fine with the locknut etc. did that and nothing. he said to pop the cover, so I did. nothing looked out of the ordinary. I spent very little time behind the clutch cover the first time so I am not familiar with it. I popped the clutch cover on the original engine. looked the same. I could spin the whole clutch basket on the new engine though and not on the first engine....hmmm....then it hit me. I took ONE look closer and realized there were no %@#!ing clutch plates in the new engine! wow.
for those wondering there ARE pistons in the engine I promise. so it was time to do something new, take out the old clutch and put it in the new engine. thats exactly what I did. I marked the lifter plate and the clutch housing so it went back together the same way. while it was apart my brother and I spent 10 minutes staring at the lifter plate and concluded there is no proper orientation. that puppy is perfectly symmetrical. I think the problem is when the plates dont line up perfectly inside the hub and create a tiny gap which translates back to the spring putting extra pressure and snapping a corner. I tapped on the bolts as I tightened and just near the end I received a huge smack and the plates lined themselves up. no cracks, no sweat. cover went back on and the sprocket cannot be turned by hand. success I believe.
  • Super Newbie
« Reply #767 on: December 30, 2013, 12:30:08 PM »
got more things on like the oil tank, battery box, and tool tray. then came the chain guard, shocks, and rear wheel. had a little fuss with the drum brake but its all sorted now and braking properly. I need to steal back my oregon motorcycle parts rectifier and regulator off of fiona to put back on yolanda. same thing with the shorty shocks. these stock ones are just for mock up, I can barely get my toes on the ground with them!
tonight I will be getting the pamco/coils, and wiring harness off the other frame and hopefully onto here. going with black spark plug wire instead of the yellow. maybe tonight I'll even be able to test fire ;) if not that's ok. I start vacation on the 1st....best way to start the new year. I am calling it Bikecation 2014! should be receiving the cb450 during that time as well. exciting stuff, ready for my 78F to go under the knife
« Reply #768 on: December 30, 2013, 12:30:14 PM »
Good diagnosing skills, Chef. You are no rookie...
Offline tweakin
  • tear down
« Reply #769 on: December 30, 2013, 01:42:30 PM »
Well done Chef!
Offline Tews19
  • I am no
« Reply #770 on: December 30, 2013, 07:11:08 PM »
Great work indeed! It pays to have two of something! Now keep the progress moving forward
1970 Honda CB750 survivor.
Offline bender01
« Reply #771 on: December 30, 2013, 08:12:00 PM »
That's going to be nicer than the first time!
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
« Reply #772 on: December 31, 2013, 04:26:52 AM »
yep the chef gets a pat on the back from the whole sohc world i think?kicked in the guts then back up and at em?better than ever!not rushing and taking time to do it good all over again,still we mustnt forget the dangerous stuff that happened here that caused it all,take care in the new year guys.
  • Super Newbie
« Reply #773 on: January 02, 2014, 11:20:40 AM »
thanks guys! encouragement means the world! I am on day 2 of my vacation and almost done! I got all of the wiring transferred, and ordered another rectifier and regulator from oregon motorcycle parts to put on the 78F since I stole them back for Yolanda. the neutral light was out so I checked the ground against the engine case and it lit up, must be the neutral switch. get the switch out and the ball that springs up and down to make contact to pass current has sunken in. there was no spring in there or something. it didnt look like the switch was serviceable so I am not even sure how it happened...I took the neutral switch off the k1 motor and popped it in and all is well.
fit all the rats nest inside the headlight bucket and buttoned her up. added a new horn just a cheap one but its MUCH louder than the old one).
proceeded to get the brake line in place. it still feels like I have weaker brakes than before though. the lever is not as stiff as my 78F that's for sure. gonna work on that. before I put the carb bank on I checked all the jets to make sure they were clear. all is well, I did a good job of draining them when I removed them. they went on with a little bit of fuss but not too bad. then the airbox top and bottom. then came a little trouble. throttle cables.
they are fairly new (what 5 months old?) OEM and when I got them in place the slides were not snapping shut. it wasnt the carbs because I checked that already. it was as if the pull cable was too tight but there was no more slack to give. when I removed the push cable it worked fine...hmmm. well after a lot of poking around I remembered my right hand grip was pushed in during the wreck. I use oury grips and they are very sticky. apparently it had gooed up the inside of the handle control where the throttle sleeve meets and very soft rubber was gunked inside causing drag. I got all of that out and everything is back to normal. no crazy adjustments on the cables needed! so the moral here is do not discount any grip drag if your throttle is sticking
pamco and coils are in place. not sure if I have them to the right coil but if it wont fire I just need to switch two plugs at the coil to see
I dropped some oil in there and the right side pipes are on. finishing cleaning the left two pipes and they are going on. then gonna get some gas in the tank and try to fire! its been raining for the last 36 hours straight and is supposed to go all night so I am not going to ride, but it sure won't stop me from giving Yolanda some new breath. thanks for reading
Online Johnie
Re: Yolanda 2.0 Almost there!
« Reply #774 on: January 02, 2014, 12:08:59 PM »
Ahhhhhhhhhhhhhh...the last 2 pics chef really looking good! And that Honda blue/green tank in the background adds a nice touch. My hat is off to you coming back from something none of us want to experience.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
