Author Topic: 76 Hybrid Cafe  (Read 5672 times)
Offline steved650
Re: 76 Hybrid Cafe
« Reply #25 on: December 30, 2012, 03:34:43 PM »
Damn nice work.  I'm pulling the motor on my 1980 cb650.  Did you paint your engine (the jugs obviously) or polish the aluminum?  Looks great
Offline dbritt
Re: 76 Hybrid Cafe
« Reply #26 on: January 01, 2013, 12:01:26 PM »
Painted with duplicolor ceramic hi temp. Then polished the fins.
1976 CB750K
1981 GL1100
1999 X-1 Lightning
2003 FLHT
2007 127" Rigid Frame
Offline dbritt
Re: 76 Hybrid Cafe
« Reply #27 on: January 02, 2013, 09:49:59 PM »
Tracked down the blown main fuse issue. The 40 year old indicator light insulation was cracked and shorting out. Cleaned that up and all seems good.
I have to mount the exhaust and should be able to fire the motor.
1976 CB750K
1981 GL1100
1999 X-1 Lightning
2003 FLHT
Offline Supermex01
Re: 76 Hybrid Cafe
« Reply #28 on: January 08, 2013, 06:05:21 AM »
I like where you going with that.
Did you make your own seat?
Offline dbritt
Re: 76 Hybrid Cafe
« Reply #29 on: January 08, 2013, 07:37:42 AM »
Thanks, ebayer named hot rod metal made the seat to my specs.
1976 CB750K
1981 GL1100
1999 X-1 Lightning
2003 FLHT
Offline Supermex01
Re: 76 Hybrid Cafe
« Reply #30 on: January 08, 2013, 08:23:40 AM »
It all looks nice.
Great job on the details
Offline dbritt
Re: 76 Hybrid Cafe
« Reply #31 on: January 11, 2013, 02:44:39 PM »
I was able to fire the bike today, she started almost immediately, blew a little smoke then ran clean, I had a little coughing out the carbs until it warmed up but ran pretty smooth after that. Did a couple of cycles on the lift only as I was using a gas bottle. No leaks evident at this point.
Cant wait to get her out on the road! Just need final paint. I mounted an oil cooler but don't have it hooked up yet so just using stock filter setup. At the very least I will run a spin on filter.
Thanks again for everyones help!
1976 CB750K
1981 GL1100
1999 X-1 Lightning
2003 FLHT
Offline dbritt
Re: 76 Hybrid Cafe
« Reply #32 on: January 11, 2013, 02:46:18 PM »
Oh yea, still need upholstery on the seat pan..............
1976 CB750K
1981 GL1100
1999 X-1 Lightning
2003 FLHT
