Author Topic: My CB 750 full custovation (Front and rear shocks,new harness,controls ignition)  (Read 7047 times)
Offline Supermex01
I got it runing did some tunning, rejeted the carbs fixed some electrical issues and now its all apart.
I got all the parts from the powder coating
I do need a triple tree as mine is bent!
Any help will be appreciated!
I also need a pair of fork tubes
« Last Edit: January 08, 2013, 01:17:20 PM by Supermex01 »
oldbob
Re: My CB 750 full restoration
« Reply #1 on: December 17, 2012, 08:22:05 AM »
That looks pretty terrific.
Regarding fork tubes, I just bought a set from Frank's Maintenance and Engineering (http://www.frankmain.qpg.com/) for my 400. The quality is impressive. Including shipping, I paid slightly under $300.
Since they make the tubes, you could get those 12-overs that you've always wanted.  8)
Bob
Offline toytuff
  • "watching the pinheads"
« Reply #2 on: December 17, 2012, 02:06:52 PM »
I have a set off of my 1977 750k. Lowers are polished, few marks. Completely rebuilt so bolt and go.
tt
Offline gto_ron
« Reply #3 on: December 17, 2012, 06:09:13 PM »
Your bike looks great!  I'm restoring a 76 750K.  How did you get the carbs so clean?
76 CB750K
72 CB350F
64 GTO
why yes, I am old-school, so what?
These are the good old days.
Offline wenger828
« Reply #4 on: December 17, 2012, 09:15:01 PM »
looks great.. they were able to powder coat the motor without taking it all apart?
78' cb750F SS first cafe build! check it out here
http://forums.sohc4.net/index.php?topic=116603.0
Offline Cabilao
  • Diving and Driving
    • Sea-Explorers Watersport
« Reply #5 on: December 18, 2012, 03:07:36 AM »
beautiful bike. the gold/silver mix looks great.
before:
Kreidler RMC(50cc)
CB400N(first bike)
RD350LC(more than one)
XS850(great bike)
CB900F(wish i still have it)
FZR1000(too fast)
Rickman CR900(sold for a good price)
now:
Rusi 125
CB 125 CL(just for fun)
Yamaha XTZ 125
CB750P7(mystery bike)
77/78 cool 2 member
Offline Supermex01
« Reply #6 on: December 18, 2012, 05:47:51 AM »
[/ftp][/ftp]
I took them apart then polished the bodies and painted them with gasoline resistant clear.
Order the OEM rubber boots the carb where tuned and rejeted so all I got to do is synchronized them when running.
Offline Supermex01
« Reply #7 on: December 18, 2012, 05:52:20 AM »
It is a lot of work the engine was painted with ceramic heat resistant paint and I took all the covers off to powder coat.
At the same time I repalced the case bolts with anodized allen bolts
Follow the full buils in facebook at:
www.facebook.com/supermex01
Offline Supermex01
« Reply #8 on: December 18, 2012, 09:11:11 AM »
I think I just scored this item getting quotes for two day fed ex trying to beat the x mas rush
Offline Xnavylfr
« Reply #9 on: December 18, 2012, 10:54:32 AM »
Very Nice Bike!!
 That new TRIP TREE looks good also but it kinda throughs your RESTORATION off.
TO RESTORE= TO rebuild to ORIGINAL CONDITION!!!
It will look nice but your' complete frontend wiil be different, ie, Handlebar mounts, gauge mounts.
Xnavylfr(CHUCK)
Offline Supermex01
« Reply #10 on: December 18, 2012, 05:08:44 PM »
I feel you man but I thought about this.
As long as I can bring the bike back to his original state I'm going to take a chance on it. All the bolt paterns are there for the original stuff, plus there is brake manifold concealed on the bottom part of the base with an connection for the brake lanes already build in.
Is a clean set up.
All stock harware still can be place on it plus it has additional options for custom items.
It's also 25% lighter.
And it's also not in stock till next year so I 'll have to move on with out it any way.
New project, my rear wheel is in bad shape.
I'm thinking on a spoke wide rear wheel set up 16x5 stock hub and better lower rear shocks.
All the original parts will be restored, cataloged and neatly put away for future use.
Offline wenger828
« Reply #11 on: December 18, 2012, 05:21:26 PM »
cycle x's triple tree? ordered mine like 3 days ago.. can't wait to get it, along with some anodized bolts as well
Offline Supermex01
« Reply #12 on: December 19, 2012, 08:18:49 AM »
They told me they where out till Jan.
I ordered a week ago assured that it was in stock
I just got the call yesterday wuth the bad news
Offline Garystratos201
  • I have never been a
« Reply #13 on: December 20, 2012, 10:38:21 AM »
If it doesnt work out I got a matched set upper and lower needs blasting and painting .Make me an offer.............Gary
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline Supermex01
« Reply #14 on: December 21, 2012, 01:32:00 AM »
We I finnaly got around to check the triple tree,.
It's not bent it was one of the fork tubes so pitted that would not go all the way as the other did so it loked like somthing was wrong.
It's all good.
But the fork tubes needed replacement and I can not find a replacement.
Offline lumberjack_964
« Reply #15 on: December 21, 2012, 07:20:59 AM »
I really like what you have done with the engine. I want to do the same thing with the black powder coating and chrome accents. How did you prep the engine casing before you had it painted? did you bead blast it or hot tank it or both?
Offline Supermex01
« Reply #16 on: December 22, 2012, 09:26:57 AM »
First I use degreaser and washed the engine.
Remove carbs and anything that is on the way.
Cover any opening exposed with tape and such.
I got a cheap blasting gun ( you will need compressor) and I used baking soda, no harm there and you can do it outdoors.
Then sandpaper away.
U used high temp engine paint. Duplicolor ang VHT (speel check) make ceramic coating for it.
It comes in many colors after it cures its resistant to gasoline.
Follow instuctions on the can.
If you like your shiny they also make a high temp clear.
You can do engine in or out of the frame, I suggest out.   its easier.
This is what that bike look like when it first hit the door in my garage
It ended up looking like this:
Full resoration/ customization job.
Happy customers
I document a lot of this stuff.
If you like to see go to
« Last Edit: December 22, 2012, 09:38:17 AM by Supermex01 »
Offline Supermex01
« Reply #17 on: December 24, 2012, 10:11:48 AM »
My coil wires are crap
Will need replacent
I only want to replace the coils  for now any suggestions?
What's best?
Offline Supermex01
« Reply #18 on: December 29, 2012, 10:42:54 AM »
What could it be?
Offline Supermex01
Re: My CB 750 full restoration (Dynatek ignition arrived)
« Reply #19 on: December 29, 2012, 02:27:57 PM »
My ignition got cabels were bad so out with the old and in with the new.
Points are gone!
Offline Tews19
  • I am no
« Reply #20 on: December 29, 2012, 04:03:50 PM »
Points are gone!
NICE! What that set you back if you do not mind and who did you order through?
1970 Honda CB750 survivor.
Offline Supermex01
Just got the front forks complete from John AKA Toy Stuff  I deffinately recomend him as a seller.
Very nice knowlegable guy excellent packing job.
Thanks John!
I also installed the ignition as well as new harness.
I'm watting for some items I oreder from Vinatge 750 to have all electronics, rubbers correct.
Watting for the two hubs and chrome spokes from X
Got aluminum rims to go with it. It should be cool.
« Last Edit: January 07, 2013, 09:02:54 AM by Supermex01 »
Offline Tews19
  • I am no
Those fork tubes look great
Offline Supermex01
Im going to the barn to get another project bike
What would it be?
Look John I think thats your bike. ;D
Offline Tews19
  • I am no
The barn or honey hole? Those are all yours? HSGDIAJMF...
