Author Topic: K6 single carb, SOHC  (Read 14952 times)
Offline AstroWing
  • Find in a barn, cut, weld, grind, paint, ride, repeat.
« on: December 26, 2012, 06:37:26 PM »
I'm new here just finishing this bike. Really happy with the single carb. This bike is so much fun to ride and much faster than bigger bikes I've ridden. I made the single carb manifold myself, thinking of offering duplicates for sale if anyone is interested.
Have some bikes, need one more.
Offline AstroWing
Re: K6 single carb, SOHC
« Reply #1 on: December 26, 2012, 06:41:58 PM »
I call it: CR 750 Nelsonore. 836 kit, battery under the seat, oil tank under the gas tank, dyna ignition, mono shock, runs great.
Offline AstroWing
« Reply #2 on: December 26, 2012, 06:47:19 PM »
Here is my manifold. I know lots of people will say the runners are unequal, pulses are off, etc. All I know is this bike runs smooth, very fast, is fun to ride and so much easier to work on.
Offline AstroWing
« Reply #3 on: December 26, 2012, 07:00:18 PM »
Got carried away with the Sawzall.
Offline AstroWing
« Reply #4 on: December 26, 2012, 07:02:04 PM »
Some more work in progress pictures
Offline AstroWing
« Reply #5 on: December 26, 2012, 07:08:09 PM »
Electronics under the seat
Offline AstroWing
« Reply #6 on: December 26, 2012, 07:10:52 PM »
Ready for powder coat. Went with 80% gloss black.
Offline AstroWing
« Reply #7 on: December 26, 2012, 07:17:11 PM »
Made a simple switch plate
« Reply #8 on: December 26, 2012, 07:31:57 PM »
Looks fantastic. How would you compare the performance of the single carb vs 4 stock?
Offline AstroWing
« Reply #9 on: December 27, 2012, 03:06:23 AM »
Hello, the bike was not running right when I bought it. I rebuilt the carbs and got it to run pretty well for about 100 miles then it went to 3,4,3 cylinders at random. I took the carbs back off took them all apart and found nothing wrong. It ran well for another 100 miles or so then, same thing. I took the carbs off again and decided to never mess with them again. I started this whole project because I hated those carbs so much. To answer your question, I own a ZX1400 (some say the fastest production bike) this little Honda feels as fast for the the first 50 yards. I think a stock 750 may have more top speed but 0 - 90 I bet I'll be way ahead. I purposely kept the carb small (37mm) because I wanted the acceleration, stop light to stop light performance and that is what I have. Put a bigger carb on and you'll get more top end.
I made 10 extra manifolds, I will sell them if anyone would like to buy one, let me know.
Offline trueblue
« Reply #10 on: December 27, 2012, 03:35:39 AM »
With that single carb, I would imagine it would pull like a tractor until the revs get up, then it will get asthmatic at higher revs.  The only thing you will have to keep an eye on is the outer 2 cylinders could run lean at higher revs due to the fuel sheeting as it rounds the bend in the manifold.  I have seen a few single carb setups on these bikes and I have never been overly impressed, mind you they do idle smooth.  If I was to do a similar setup, I personally would go a twin carb setup, with one feeding 1&2 and the other feeding 3&4.
1979 CB650Z
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #11 on: December 27, 2012, 06:04:40 AM »
Nice build AstroWing! I like it. I bet it will run just fine like you said for your purpose. After all cars with 8 cylinders can run on 1 carb, and if your want more top end put a bigger MM carb on it!
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #12 on: December 27, 2012, 09:39:15 AM »
Great looking bike.  You did get aggressive with the sawzall and frame mods, but she's a beaut.
The manifold looks decent, too.  I wonder how much high end you lose with the single carb set up vs. a twin set up like Cycle X's.
Offline AstroWing
« Reply #13 on: December 27, 2012, 01:41:40 PM »
I would need a dyno run to determine the top end power, then I would have a number on a piece of paper to talk about. I have a ZX14 and love the feel when I open it up. This bike does almost the same for me.
Just got my seat from the upholstery shop. What do you guys think?
Offline trueblue
« Reply #14 on: December 27, 2012, 02:05:20 PM »
It would be interesting to see the dyno results, I would expect a shift in the torque band to a lot lower in the rev range and less peak HP.  But by how much, I'm not certain.  Like I said before keep an eye on the outer 2 cylinders, they will run leaner then the inner 2 at high revs.  If they run lean enough it could cause damage to your engine.
1979 CB650Z
Online dusterdude
« Reply #15 on: December 27, 2012, 02:11:49 PM »
How much and can i get better pics of the manifold
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #16 on: December 27, 2012, 02:20:08 PM »
+1. And what kind of carb is that? mikuni??
Offline AstroWing
« Reply #17 on: December 27, 2012, 05:28:54 PM »
Thanks for the kind words about my Honda project.
I made extra manifolds, thinking of offering it as a ready to go kit. Throttle, throttle cable, manifold, clamps, rubber couplings and air filter. I am very happy with the jetting for my 836, 4 into 1. Next I'll install one on a near stock 750 and get the jetting right so I can predict what jetting will work on a more stock bike. I should have a price and kits on the shelf in 30 to 60 days.
Here is a couple shots of what happened after I rode around town a little: my clutch started slipping and began to tear the knobs off my trials tires
Offline AstroWing
« Reply #18 on: December 27, 2012, 05:30:46 PM »
Look close at this Dunlop trials tire. Guess I'll have to go to a more conventional tire.
Offline AstroWing
« Reply #19 on: December 27, 2012, 05:40:08 PM »
I also had extra oil line adapter plates made to get rid of those stock oil lines. Look  under the clutch picture. Will get them back from the anodizer in a couple of weeks.
Offline harisuluv
« Reply #20 on: December 27, 2012, 05:52:08 PM »
Really cool.  I admire the originality, nice job.  How did they fasten the upholstery to the seat?  I want to get a very similar style/look.
Offline AstroWing
« Reply #21 on: December 27, 2012, 06:01:56 PM »
Started on my next project... Guess what the first thing I tossed was?
Offline AstroWing
« Reply #22 on: December 27, 2012, 06:04:06 PM »
Thanks, I used Velcro to hold the padding to the fiberglass.
Another picture of new project.  Stay tuned.
Offline brandEn
« Reply #23 on: December 27, 2012, 08:55:02 PM »
Looks great! I think you need to post some more info and pictures of your carb setup. Looks interesting for sure.
Offline AstroWing
« Reply #24 on: December 28, 2012, 03:03:39 AM »
Thanks, I have been running the bike with the carb/manifold in mockup.... Ugly blue silicone hose connectors and cheap hose clamps. I finally found some hose and clamps that I like but had to have the clamps chromed. The chrome shop said they will have everything late next week. I'll send pictures then, if I'm happy with how it looks. Sorry for the delay.
I collect 1974 Honda Elsinores here is a picture of one of them. Hope it helps explain why I have dirt bike tires and other features on this cafe racer.
