Author Topic: Anyone have a DOHC 750 and a ruler???  (Read 1288 times)
Offline trueblue
« on: December 30, 2012, 12:41:02 AM »
I was wondering if anyone could help me out.  I'm chasing a couple of measurements of the front end of a DOHC 750.  The 2 measurements I'm looking for are from the centre of the front axel to the centre of the lower caliper bolt hole on the leg, and also the distance between the caliper mount bolt holes, centre to centre.  If you can provide these measurements it would be greatly appreciated.  ;D
1979 CB650Z
Offline trueblue
Re: Anyone have a DOHC 750 and a ruler???
« Reply #1 on: December 30, 2012, 03:46:14 PM »
??? No-one ???
1979 CB650Z
Offline Magpie
« Reply #2 on: December 30, 2012, 05:45:47 PM »
I have one but don't have it apart, you may want to try these guys http://www.cb1100f.net/index.php  or http://www.cb750c.com/index.php   Both forums have ben very helpful for me. Cliff.
Offline trueblue
« Reply #3 on: December 30, 2012, 06:12:03 PM »
Cliff, you shouldn't need to pull it apart, all I'm after is a near enough measurement to know I'm not barking up the wrong tree.  If you could please measure the points in the picture I have marked below it would be greatly appreciated. ;D
1979 CB650Z
Offline Magpie
« Reply #4 on: December 31, 2012, 03:47:46 AM »
Okay, later today. Cliff.
Offline trueblue
« Reply #5 on: December 31, 2012, 03:53:04 AM »
Thankyou ;D
1979 CB650Z
Offline mono
  • Definitely no
« Reply #6 on: December 31, 2012, 04:30:48 AM »
I'd volunteer butt my forks are off...
Sent from my SPH-L710 using Tapatalk 2
Offline trueblue
« Reply #7 on: January 01, 2013, 12:20:52 AM »
I've got it, they are 65mm between the caliper mounts and 65mm between the axel centre and lower caliper bolt, exactly what I need ;D
1979 CB650Z
Offline Magpie
« Reply #8 on: January 01, 2013, 08:19:04 AM »
Good! I got very busy moving a friend yesterday and was going to measure today but you beat me to it. Cliff.
Offline trueblue
« Reply #9 on: January 01, 2013, 02:38:23 PM »
Thanks anyway Cliff, turned out a mate of mine had one hiding in the back of his shed.  I should have know though, he has everything else there ;D.
1979 CB650Z
