Author Topic: Too Much/Not Enough...Engine Carnage etc.!!!!  (Read 6607 times)
Offline Bill/BentON Racing
    • BentON Racing
Re: Too Much/Not Enough...Engine Carnage etc.!!!!
« Reply #25 on: January 06, 2013, 06:06:09 PM »
I was going to comment did the other sets "match" those? WOW!!! Wrong didn't WORK!! ;) ;D More Carnage,been posted before,but seems like it belongs here! ;D Bill
BentON Racing Website
BentON Racing Facebook
Offline sohc boy
« Reply #26 on: January 06, 2013, 09:13:02 PM »
.... 440 chrysler .....  DAMN  the big end rattle ....FULL THROTTLE !
« Last Edit: January 06, 2013, 09:16:37 PM by sohc boy »
i live by the voice inside my head
« Reply #27 on: January 06, 2013, 09:25:30 PM »
What's the rest of the story??? ;)
Offline sohc boy
« Reply #28 on: January 07, 2013, 06:19:23 PM »
 Scottly,( i shouldn't have .....but i did )..... it had a lot a drag strip miles on it when i bought it  in U.S. , i clocked up around 40 passes, an around  7000 road  mls ,driving from east coast to L.A, by then it was fairly rattly,which i thought , when i get it back home i'll freshen it up , ( had cast crank ), the temptation back home with a new toy was too much ,( changed oil few times, added some magical additive, said few prayers )drove it to a local drag strip ,run a few passes , all good ,but on the way home ,started gettin real noisy , so i  turned the radio up, an hoped for the best , ...nearly made home (about 5 ks to go )
« Reply #29 on: January 07, 2013, 06:29:59 PM »
Shoot, I was hoping to hear a tale about big boost, laughing gas, or fuel... :( ;)
Offline sohc boy
« Reply #30 on: January 07, 2013, 06:34:41 PM »
 HAHAHA.... no.......just slow painfull death ..
« Reply #31 on: January 07, 2013, 06:37:59 PM »
Looking at the pic again, I'm guessing a rod bolt failed first?
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #32 on: January 08, 2013, 11:32:17 AM »
Too much nitro tuneup... Downright impressive when you consider that's a billet block.  :o
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
  • Moderator
« Reply #33 on: January 08, 2013, 01:35:06 PM »
Not an expensive blow up then.  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Sam. ::)
Offline sohc boy
« Reply #34 on: January 08, 2013, 07:59:56 PM »
...not sure scottly ,think jus ( rod blued from heat ) rattled till no bearing ..then let go
« Reply #35 on: January 08, 2013, 08:44:03 PM »
Reminds me of a local legend: "Ted" was putting together a hipo short block 440 for his 'Cuda. Working late into the wee hours of the morning, and with no small amount of beer, he fit the last piston/rod assembly into the block, and snugged down the rod bolts. At this point, he decided to hit the sack. He placed the oil pan over the block to keep the dirt out. The next day he returned to the project, saw the pan fitted, and proceeded to bolt it down, thinking that was where he left off. He never torqued the last rod. The motor lasted about 5 minutes... ::)
Offline sohc boy
« Reply #36 on: January 09, 2013, 01:12:32 AM »
ha ha ......you can laugh if you want ..did somthing similar with a honda motor , in  hurry before a race late  at night , have another small 440 carnage i'll put up
Offline sohc boy
« Reply #37 on: January 09, 2013, 04:00:48 AM »
rocker arm adjusters decided to break ,in the middle of Arizona or New Mexico, bent push rods , we found out why later , notice the state of the art Wall Mart tool kit
« Last Edit: January 09, 2013, 04:04:31 AM by sohc boy »
Offline NitroHunter
« Reply #38 on: January 10, 2013, 11:50:21 AM »
There's a saying in the nitro pits if the rods stayed in it through the burn out, the diver (bottom end guy) did his job...  ::)
Unfortunately I have also seen them exit while warming up on the jackstands - idling on alcohol. Ouch.  :o
Offline Short shins
  • New Zealand
« Reply #39 on: January 14, 2013, 11:32:35 PM »
Well it is a SOHC just not a 4
Local track Manfield New Zealand. Chasing a FZ Yamaha (memory says it was a 1000 but probably a 750) He was faster on the straights but I had him in thru the esses. About to line him up for a big dive into the hairpin when bang!, motor was still running, just vibrating a bit. Got back to the pits, spotted the oil leak and knew I had done another barrell!
Sad looking Crew Chief
Looks fairly innocent
Carnage revealed back in the shed
I'll try and find the damage a broken rod caused  :(
I love sleep. My life has the tendency to fall apart when I'm awake, you know?”
Ernest Hemingway
    • BentON Racing
« Reply #40 on: April 06, 2013, 08:24:33 PM »
Saw this up close and personal today! ;D What caused that hole? You tell me! ;) ;D FJ1200 legends car
Well it did this!!
What basket?  ;) ;D
OK,so what happened? ::) ;D Bill
