Author Topic: Front end swap  (Read 650 times)
Offline mattporter637
Front end swap
« on: December 31, 2012, 06:04:30 AM »
Does anybody know if a 06 or later GSXR front end will fit a 78 550k?
Offline Roach Carver
Re: Front end swap
« Reply #1 on: December 31, 2012, 06:40:56 PM »
http://forums.sohc4.net/index.php?topic=63784.0
go to the google custom search right up there on the left. search front end swap. read away.
Offline bugs101logan
Re: Front end swap
« Reply #2 on: January 02, 2013, 10:36:29 AM »
i did a 06 gsxr 600 font end swap all balls racing sells the bearings you will need for the neck and becarful of the forks hitting the tank now depending on what wheel you use keep in mind you will have to make a special axles or bushings to fit another wheel and the stock suzuki throttle cables wont work i had to cut mine
