Author Topic: Headlight Casing Fix?  (Read 929 times)
Offline farinhite
« on: January 02, 2013, 01:55:58 PM »
So I have a cracked headlight casing (near the fork stations). I've heard that you could fix this by soldering the casing back together from the inside, sanding, and re-painting.
Has anyone done this? I was thinking I might give this a try before buying a new OEM/NOS headlight casing. Those things aren't cheap.
Offline farinhite
Re: Headlight Casing Fix?
« Reply #1 on: January 02, 2013, 01:56:12 PM »
Or if anyone has an extra CB500 K headlight housing laying around and wants make a few bucks let me know. :-)
Offline Viktor.J
  • Breaking in the forum
« Reply #2 on: January 02, 2013, 02:49:57 PM »
I have The same problem also, and been looking at some plasting padding With fiber glas. But feels that someone should've done this beafore :)
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
« Reply #3 on: January 02, 2013, 02:50:42 PM »
ABS plastic can be welded.  But, as this plastic ages it loses some of its make up to evaporation.  Melting/fusing such plastic makes it shrink and become more brittle.  You will, at least, need to add filler rod, and learn a new welding skill.
A bit easier is superglue, and a bridge patch (at least on one surface side) of nylon tape and epoxy.  The tape is applied to a clean surface that has be roughed up or even grooved, so the epoxy can grab on to something when subjected to later stress.
Offline farinhite
« Reply #4 on: January 02, 2013, 03:42:21 PM »
Like this option a bit better. Thanks!
Anyone know about re-painting a headlight casing?
Offline Kevin D
  • SE Michigan
« Reply #5 on: January 02, 2013, 03:44:00 PM »
I got a used one, $15, black. Repainted to match orginal color.
http://www.newmotorcycleparts.com/
You have to call for used parts 317 634 7550
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline RSchaefer
« Reply #6 on: January 03, 2013, 05:44:58 AM »
I had a crack at one of the mounting bolts and per the forum used the super glue/baking soda route and it came out perfect.  Tried to flex the crack after the super glue and it would not budge.  Sanded it down and painted it, no problem!  I would highly recommend that process if what you have is a crack to fill!!
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline alancop
  • Vroom, vroom!
  • Vroom, vroom!
« Reply #7 on: January 03, 2013, 06:16:42 AM »
Is the 550k headlight bucket the same as the 500k headlight bucket? If so I have one, if you would still like a new one.
It's almost twice as old as me, I don't know how the hell it works!
