Author Topic: RC Stroker Rods  (Read 5020 times)
Offline cavebear
RC Stroker Rods
« on: January 03, 2013, 08:49:23 AM »
Did RC ever make a 4mm stroker rod? If so, did they also make the crank to go with it?
1975 MotoMartin 836cc
1976 Rickman 1150cc Turbo
1977 Seeley 890cc + 1/4 stroke
3 parts bikes,1970K0 to 1978ss
Get paid to do it,it's work; pay to do it,it's a hobby
Re: RC Stroker Rods
« Reply #1 on: January 03, 2013, 10:13:50 AM »
 They made them , I have a set of the rods, used ones..
« Last Edit: January 03, 2013, 12:13:55 PM by 754 »
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: RC Stroker Rods
« Reply #2 on: January 03, 2013, 10:20:08 AM »
They made them , I have a set of thecrods.
Used, or new Frank?
Offline bear
  • Leeton in Australia
Re: RC Stroker Rods
« Reply #3 on: January 03, 2013, 03:58:54 PM »
Stroker rod?
What's the go, are they shorter?
Brian
Offline cbr954
Re: RC Stroker Rods
« Reply #4 on: January 03, 2013, 04:09:02 PM »
RC Engineering listed the rods and crank in there catalog.  I know Ken at cycle x had a stroker crank and rod set, its still up on there used performance parts page.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline Greggo
  • Somebody's
Re: RC Stroker Rods
« Reply #5 on: January 03, 2013, 07:14:04 PM »
I couldn't find it...got a link?  Is it the 'Pawn Shop' section now?
Offline Bill/BentON Racing
    • BentON Racing
Re: RC Stroker Rods
« Reply #6 on: January 03, 2013, 07:30:11 PM »
I think he sold them,Maybe removed from site? bill
BentON Racing Website
BentON Racing Facebook
Offline cbr954
Re: RC Stroker Rods
« Reply #7 on: January 03, 2013, 09:08:05 PM »
« Last Edit: January 03, 2013, 09:11:37 PM by cbr954 »
  • Moderator
Re: RC Stroker Rods
« Reply #8 on: January 03, 2013, 10:46:53 PM »
Stroker rod?
Brian
Half the length that the crank has had the stroke increased by.
Sam. ;)
Offline bear
Re: RC Stroker Rods
« Reply #9 on: January 04, 2013, 03:36:52 AM »
Stroker rod?
Brian
Sam. ;)
Hmm.... ???
I'm gonna draw the crabs on myself again.
Reducing conrod length and increasing stroke ant a good idea.
Brian
  • Moderator
Re: RC Stroker Rods
« Reply #10 on: January 04, 2013, 06:07:27 AM »
Why's that young Brian, ;D If you use the same size rods, the piston will clatter the combustion chamber.
The only way round that is to fit a spacer under the block to give you clearance but then your valve timing will be out.
If you lengthen the stroke by moving the crank pin out by 4mm, the origional stroke will be lengthened by 8mm (the piston will rise by 4mm and fall by 4mm) so by fitting a 4mm shorter rod, your stroke is still increased by 8mm and your valve timing is not compromised.
Sam. ;)
Re: RC Stroker Rods
« Reply #11 on: January 04, 2013, 06:56:50 AM »
Stroker rod?
Brian
Sam. ;)
Hmm.... ???
Brian
Basically I agree. Jay did point out that less dwell @ TDC allows for more agressive cam profiles. Unfortunately rod angle suffers.
Offline bear
Re: RC Stroker Rods
« Reply #12 on: January 04, 2013, 06:58:48 AM »
Valve timing isn't an issue Sammy.
Rod/stroke ratio may be though.
I've never been game to shorten it up more than 1.7-1
Even those numbers load the pistons I am using up more than I would like.
Brian
« Last Edit: January 04, 2013, 08:14:51 AM by bear »
Offline bear
Re: RC Stroker Rods
« Reply #13 on: January 04, 2013, 07:32:34 AM »
Stroker rod?
Brian
Sam. ;)
Hmm.... ???
Brian
The longer rods help maintain cylinder pressure as well, but best of all they allow me to run shorter piston skirts and I just love short skirts. ;D ;D ;D ;D
Brian 8)
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
Re: RC Stroker Rods
« Reply #14 on: January 04, 2013, 11:59:02 AM »
2.0 or greater is common in the diesel industry, keeps the skirt wear down for high milage application.
There are some Pro Stock 500cid motor builders who believe that 1.9 is the magic number - but oh boy it takes tons of cubic hours and dollars to make those parts work. Some pretty tall deck heights too...
Their cam profiles make a .800" lift TF cam look wimpy.  :o
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline dusterdude
RC Stroker Rods
« Reply #15 on: January 04, 2013, 04:54:31 PM »
Sam. ;)
wow!!,sam,you're sounding like you got some book learnin
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: RC Stroker Rods
« Reply #16 on: January 04, 2013, 06:06:35 PM »
Stroker rod?
Brian
Sam. ;)
Hmm.... ???
Brian
Brian 8)
Smokey Yunick was a huge advocate of extended piston dwell....unfortunately time has mached on and some of Smokey's most sacred beliefs have been discounted and put aside. In light of that.......I do still believe for 90% of the strokers out there (Busa's, old KZ's, GS's) the longer rod with a spacer plate is the best way to go. Just my 2.
 I understand Jay's point completely but to me it is the same as offset bores....you can do it but it is application specific.
Offline bear
Re: RC Stroker Rods
« Reply #17 on: January 04, 2013, 06:15:18 PM »
Nitro,
I agree, piston failure or excessive wear is my major worry.
We have settled on 1.7 for our motors it seems to be pretty close to the mark.
The A motor uses VFR750RR pistons (very short skirts), while the B motor uses XR250R pistons that have a more conventional skirt length.
Brian
Sorry for high jack cousin cave. ;D
« Last Edit: January 05, 2013, 02:51:39 AM by bear »
Re: RC Stroker Rods
« Reply #18 on: January 04, 2013, 06:17:16 PM »
Nitro,
I agree, piston failure or excessive wear are my major worry.
Brian
Good....I'm glad I didn't waste my time on this thread. ::)
Offline bear
Re: RC Stroker Rods
« Reply #19 on: January 05, 2013, 02:49:54 AM »
[/quote]
Yeh!............. What he said. ;D ;D ;D ;D ;D ;D ;D
Brian
Re: RC Stroker Rods
« Reply #20 on: January 05, 2013, 09:11:27 AM »
 I would gladly run the "wrong stuff". If it made me go faster.
 Should mention on Goldenrods, that probably have to do some case clearancing they are pretty stout.
Re: RC Stroker Rods
« Reply #21 on: January 05, 2013, 07:05:11 PM »
...and list it on 2 threads. Trying to get to 14,000 Frank? I've been on this board 2.5 years longer with less than half the responses.....and I have plenty to say. ;D
Re: RC Stroker Rods
« Reply #22 on: January 05, 2013, 07:09:19 PM »
 Should mention on Goldenrods, that probably have to do some case clearancing as they are pretty stout.
Probably?????????
    • BentON Racing
Re: RC Stroker Rods
« Reply #23 on: January 05, 2013, 07:15:49 PM »
OK,definitely!!!!! ;) ;D 8) Bill
Offline bear
Re: RC Stroker Rods
« Reply #24 on: January 06, 2013, 01:56:01 AM »
 Should mention on Goldenrods, that probably have to do some case cleansing they are pretty stout.
With the discussions we've had lately ie; RC block's and some conrods, it's not about "the wrong stuff."
The gear we have been talking about is good gear, no doubt about that.
The argument that Mike and I are putting forward is more to do with whether the applications some of these parts are used in are appropriate.
( Sorry Mike I don't mean to preempt your opinion)
Brian
See Uncle Sammy, I can "keep it sensible" ;D ;D ;D
