Author Topic: 1975 Honda CB400F Engine Case Crack  (Read 1502 times)
Offline cgarbe
« on: January 05, 2013, 01:46:56 PM »
So I am having my CB400F restored and updated and after getting it to start (on the second kick) it started leaking oil. Come to find out there is a gob of JB Weld beneath the drain plug on the lower engine case. After some investigating we found a crack (where the JB Weld was located) that spans into the drain plug. Not sure what to do…replace the engine case (and have the engine rebuilt) or search for a new motor. Thoughts?
1975 Honda CB400F
1978 Honda CB750F
Offline MoMo
  • Ride like you're invisible
Re: 1975 Honda CB400F Engine Case Crack
« Reply #1 on: January 05, 2013, 03:48:30 PM »
If it is near the drain plug that is part of the oil pan cover and can be removed and repaired or replaced. Are you sure it is the crankcase?  Seems more like it would be the pan...Larry
Offline faux fiddy
  • bike in a box
« Reply #2 on: January 08, 2013, 01:35:41 AM »
+1
Is it 11 bolts?  You can reuse the gasket if it's not shredded, yamabond helps. You can at least clean it all and inspect the pan.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #3 on: January 08, 2013, 03:51:43 PM »
If it is the case, clean it up real well and either JB weld it again or get it carefully TIG welded in the frame.
