Author Topic: Solvent advice  (Read 2464 times)
Offline stereosilence
  • 1975 CB550K
Solvent advice
« on: January 06, 2013, 02:23:40 PM »
Long story short: I got my engine cases, block, and head blasted buy a guy who didn't really understand what I was looking for. He used sand and took all the paint off but stayed well away from all mating services or anything that could be damaged. So, now I have to go through and scrub off all remaining grease, gasket material, and sand residue.
What sort of solvents can I run through the ports and everything to degrease and scrub them clean? My plan is to scrub everything really well and then go blast it out with water at a car wash.
Offline RSchaefer
Re: Solvent advice
« Reply #1 on: January 06, 2013, 04:01:16 PM »
I'm cheap and flooded the crankcase with gas to clean everything out.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Jerry E.
Re: Solvent advice
« Reply #2 on: January 07, 2013, 12:06:42 AM »
I used a soda blaster to clean the paint/grease from my motor, but I still got media I needed to clean out. So, then I ran my case thru the dishwasher on "heavy wash" a couple times. Works well, then take an air hose to all the oil/bolt passages, to get any excess water out. Hondaman mention's using a dishwasher in his book, but I have washed everything from engine parts, to degreasing bolts, for years. I don't like car washes for cleaning parts, unless I have to. Hate the wet/greasy blowback in the face that always seems to happen.
"Why jump from perfectly good airplanes? Because the door opens."
Offline Bodi
Re: Solvent advice
« Reply #3 on: January 07, 2013, 08:11:18 AM »
Wear a rainsuit and go to a pressure wash bay. Remove the oil gallery plug , spray through all oil passages, spray into all bolt holes, etc. You will get soaked with the sprayback, but nothing else cleans the crap out as well.
Offline Toxic
Re: Solvent advice
« Reply #4 on: January 07, 2013, 08:20:07 AM »
FYI ... I don't know about the car wash booths in your area but trust me that high pressure stream will cut your skin like a hot knife in butter.  Keep your digits away.
+1 on getting soaked so pick a warm day and bring a change of clothes.
Good luck
Gary
  • 1975 CB550K
Re: Solvent advice
« Reply #5 on: January 07, 2013, 04:04:54 PM »
Yeah. This is pretty much what I had anticipated. I figured I would use chemicals and scrub off the dirt and grime and everything I could and then go blast it with water.
Offline tlbranth
Re: Solvent advice
« Reply #6 on: January 07, 2013, 05:32:35 PM »
You might do a preliminary cleanup with Brake Clean. It really gets stuff off. O'Reilly has their own brand of it that seems to usually be on sale for $2.50 or so a can. Then soak in Simple Green for a day or so. Then soda blast, then car wash.
« Last Edit: January 11, 2013, 11:28:33 AM by tlbranth »
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline shinyribs
Re: Solvent advice
« Reply #7 on: January 07, 2013, 08:05:27 PM »
I'm not trying to discount anyone else's advice,but here's what i did:
Sand blasted the cases
Duct taped any sensitive areas-the duct tape WILL stay-easily removed with lighter fluid,wipes right off
Preliminary cleaning with brushes/pipe cleaners and Purple Power
Final scrubbing in the tub with Dawn,warm water and lots of flushing.
ALL oil gallery plugs were removed and the pipe cleaners were run through.
Clean as a whistle!
Notice the 'tools of the trade' ;)
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
  • 1975 CB550K
Re: Solvent advice
« Reply #8 on: January 08, 2013, 08:34:53 PM »
Would there be any problems doing this with the block and the head? I'm not sure what other metal is in that. Is there risk of rust?
Offline shinyribs
Re: Solvent advice
« Reply #9 on: January 08, 2013, 08:40:07 PM »
I haven't gotten around to it yet,that I do plan to do this to the head and cylinders. After washing with dish detergent and soap I'll rub the steel surfaces with Marvel Mystery oil to keep them from rusting. I used to do this to all of my race engines( autos,not bikes) and spare engine when I would build/store them. Never had a problem. You really have to rub the oil on the parts though,simply wiping them down can let it rust sometimes. I guess it has to be ''worked into the pores'',at least thats my non-professional opinion  ;)
Offline Magpie
Re: Solvent advice
« Reply #10 on: January 09, 2013, 10:15:16 AM »
You MUST be a bachelor!  ;D  Cliff.
Offline shinyribs
Re: Solvent advice
« Reply #11 on: January 09, 2013, 11:19:24 AM »
 ;)It's my tub. I shall use is as I deem fit...at last while i'm still a bachelor  ;D
Offline nccb
  • 1974 CB750 Four
Re: Solvent advice
« Reply #12 on: January 09, 2013, 11:22:28 AM »
I just did something similar while my wife was away, cleaning up now for her arrival :)
Offline matt mattison
Re: Solvent advice
« Reply #13 on: January 09, 2013, 12:27:27 PM »
If you washing parts in your bathtub, you might be a redneck ;D
1975 CB550F
2011 MV Agusta Brutale 1090RR
Re: Solvent advice
« Reply #14 on: January 09, 2013, 12:34:27 PM »
;D
just for when your parts are still soaking, and you get a little odiferous....
Offline nccb
  • 1974 CB750 Four
Re: Solvent advice
« Reply #15 on: January 09, 2013, 12:53:37 PM »
I was at least using my kitchen, I still need to get the wheels out.  TO my excuse though, I don't have lights in my building.
  • 1975 CB550K
Re: Solvent advice
« Reply #16 on: January 10, 2013, 08:52:17 AM »
How about getting the crud out of the ports? My exhaust ports have heavy carbon buildup. Soak in the hot bath and run pipe cleaners through? I was out scrubbing today and there is still grease and crap in nooks and crannies here and there and it did not want to come out. I'm thinking of just doing the bathtub treatment myself and giving it my best effort and then painting.
Re: Solvent advice
« Reply #17 on: January 10, 2013, 12:18:13 PM »
Those $5 plastic totes they sell at Wal Mart work great. That way you don't have to use your bath tub . Solvents mixed with grease going down your drain should be avoided for many reasons. Your local recycling center, where you dump your old motor oil ,will usually take the degreaser/solvent left over when your done.
1975 CB550F
Offline mono
  • Definitely no
Re: Solvent advice
« Reply #18 on: January 10, 2013, 12:29:41 PM »
all the DIY car washes here have a heavy-duty degreaser spray option that works really well.  just spray it with degreaser, let is soak for a while and/or scrub it (use gloves for sure) and then rinse it with the high-pressure spray, repeat as necessary.   over the summer my buddy and i degreased the front chassis clip on his project car this way.  before we took it there, we had literally been scraping dried grease/dirt off of it with putty knives and wire brushes. for days.   about 45 mins in the car wash and $15 later, it was almost 100% clean.
Offline shinyribs
Re: Solvent advice
« Reply #19 on: January 10, 2013, 08:55:26 PM »
Good point! You definitely dont want all that nasty stuff going into your plumbing.
Most coin car washes will rake you over the coals if they catch you degreasing parts into their pits. I know if I owned one of those stations I'd be pretty upset to find it being used as a community parts washer. JMO of course.
  • 1975 CB550K
Re: Solvent advice
« Reply #20 on: January 11, 2013, 07:09:11 AM »
Could be. Mine is truly just dirty. It has some carbon build up and baked on crud in the tight places. I'm not even sure we have those drive up places around here. I'll have to check.
  • 1975 CB550K
Re: Solvent advice
« Reply #21 on: January 22, 2013, 07:43:06 AM »
Well, I haven't found a pressure sprayer place yet. I decide to try the tuperware tub treatment. I let some purple power soak into the crud and then added liquid soap and cover it all in hot water and let it sit. I did a lot of scrubbing and an impressive amount of sludge was left at the bottom of the barrel. However, I didn't come close to removing all the nasty. I had hoped a lot would loosen up and rinse off, but it didn't at all. Only scrubbed parts came clean. The other thing is that I started to get some rust in the cylinder and around the valve guides. Also started finding washers from valve guides. I didn't even know those came out. Should I take them out? If so, how?
Offline grepper
  • Busted Knuckles
Re: Solvent advice
« Reply #22 on: January 23, 2013, 08:51:24 AM »
Mineral Spirits breaks up oily crud well.  I've also heard of people using Kerosene.
I like using a Long Bristle Brush like those you would use to clean wheels on a car.  A long Bristle Wire Brush the real stuck on stuff between the fins.  Also a pick set is good to have too.
