Author Topic: Engine valves on rebuild  (Read 501 times)
Offline Lost and Confused
  • Bob
  • An old fart !!
« on: January 07, 2013, 04:29:04 PM »
Hello,  I have a question about valves. I'm rebuilding my 750, I've bought new valves, springs, and retainers and wanted to know if lapping the valve seats is always  neccesary. The dome area of the head had a lot of black soot. Former owner ran it rich, I guess. Thanks for any info.
Offline tlbranth
Re: Engine valves on rebuild
« Reply #1 on: January 07, 2013, 05:22:52 PM »
I would check the guides for wear and replace them if necessary and have the valve seats refaced. Then lap very lightly. I'm not a fan of heavy lapping because, if you think about it, lapping wears away the part of the valve seat that's touching at the time. When it gets hot and rides up a tad on the seat, You're into new, unlapped territory a lttle bit.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline lucky
« Reply #2 on: January 07, 2013, 05:38:03 PM »
You must check the valve guides for wear. No use lapping a wobbly valve. Do it the way the book says.
.004 max tolerence.
