The chain sound (background hiss) is your cam chain. Hard to tell how loud it actually is, since the video likes to distort that. Run your cam chain tensioning procedure as per the manual. The intermittent rattle is the bottom end from a rough idle. Check your timing and adjust it as per manual, and if that doesn't fix it, sync your carbs. It's a bit fiddly, but not all that hard really.
