Author Topic: 1974 cb 750 build  (Read 7067 times)
Offline zoom74cb
  • 1974 cb 750 2002 dyna FXDX . 2001 fxdx t sport
1974 cb 750 build
« on: January 07, 2013, 05:54:39 PM »
Well hello all...some of you may know im building a K4. Thought i would post some pictures of some of the parts that were cleaned and/or refinished. Its kinda a slow process because of a stupid BUGET thing..hehe  but it wiil come together. More to come from Daytona Beach for sure!!
Offline zoom74cb
Re: 1974 cb 750 build
« Reply #1 on: January 07, 2013, 05:56:43 PM »
Rear brake drum plate ..drilled..and polished...took quite some time to hand sand this and polish.
Offline zoom74cb
« Reply #2 on: January 07, 2013, 05:58:19 PM »
speedo rebuilt...I had posted a thread on this
Offline zoom74cb
« Reply #3 on: January 07, 2013, 06:00:05 PM »
Tig repair on lower tree and bead blasted...still have to grind the weld
Offline zoom74cb
« Reply #4 on: January 07, 2013, 06:03:45 PM »
when i brought it home....and some teardown pics...had thought of using drag bars ...but leaning towards clubmans...i think :D
Offline Tews19
  • I am no
« Reply #5 on: January 07, 2013, 09:45:19 PM »
Interesting seat you got there. What are your plans for the 4-4 pipes?
Subscribed
1970 Honda CB750 survivor.
Offline NewOldSchool
  • Apprentice
« Reply #6 on: January 08, 2013, 04:28:08 PM »
Hey I really like those gauge faces, best "custom" ones I've seen.
Not putting miles on your bike is like not having sex with your Girl Friend so she'll be more desirable to her next Boy Friend.
Offline iron_worker
« Reply #7 on: January 09, 2013, 06:22:40 AM »
Link to your speedo build thread?
Lookin good.
IW
Offline zoom74cb
« Reply #8 on: January 09, 2013, 11:34:07 AM »
Well Iron_Worker.....i still am new to navigating this scene  Lol  But i had posted the speedo build in the SOHC thread...
Offline zoom74cb
« Reply #9 on: January 09, 2013, 11:42:40 AM »
I probably will hold on to the pipes for now TEWS19  but they have rust holes in them ..not as good they look in the pics.
Offline zoom74cb
« Reply #10 on: January 29, 2013, 11:01:01 AM »
Well got done with the front brake caliper rebuild..The bracket i mirror polished just the top..and left the rest of the bracket natural with a coat of mothers polish to give it a satin look.  All i need now is a speed bleeder and stainless piston ..which are aon order.
Offline zoom74cb
« Reply #11 on: February 02, 2013, 05:32:51 PM »
Small update...Just restored the cracked and battered headlight to like new condition. Cracks repaired and new spacers installed with headlight ring and tri-bar headlight.
Offline zoom74cb
« Reply #12 on: February 02, 2013, 05:35:58 PM »
more pics of finished headlight.. This project is slow going but i am making progress.
Offline zoom74cb
« Reply #13 on: February 02, 2013, 05:42:48 PM »
Hard to see..but all cracks were V-grooved and filled with a two part epoxy...Then sanded and VHT chassis epoxy used to give it a satin finish. Stainless button head screws replace the factory phillips bolts
Offline harisuluv
« Reply #14 on: February 03, 2013, 05:42:20 PM »
I see really great work with attention to detail.  It takes times to do but the finished product always speaks for itself.  I am of the same school of thought, carry on sir!
Offline zoom74cb
« Reply #15 on: February 05, 2013, 04:06:05 AM »
High guys..i am doing a mock-up of the master cyl and left handlebar controls on a set of test bars...My factory switches were very very bad and broken..Awhile back i found these aftermarket switches for about $10 They have slide contacts like the factory ones and bullet connectors at the end. The only thing is the wires are a slightly smaller gauge than factory. Think i will have any problems??  The switches are cast like the oem. The turn signal is not the self cancel type though.  I will probably be using this master (2004 ZX636) and the clutch perch from the same bike. Kinda like the way it looks. What do you all think???
Offline zoom74cb
« Reply #16 on: February 05, 2013, 04:09:17 AM »
OHH..and  the switch will accept ONE cb 750 trottle cable.  Was thinking of running one throttle cable anyways
« Reply #17 on: February 05, 2013, 04:36:52 AM »
Good looking switches, where are they from?
I believe one cable is not a problem as long as you make sure it does not jump out of the carb end anchor.
Offline zoom74cb
« Reply #18 on: February 05, 2013, 06:10:49 AM »
Got the switches from Ebay ....They were cheap enough so i got the right and left side to see how the quality was. Really not bad at all.
Offline Viktor.J
  • Breaking in the forum
« Reply #19 on: February 05, 2013, 09:39:48 AM »
Great work Zoom ! Not slow going at all, really neat progress. Love the work you did with the lamp, I'm probably trying to do something the same to mine ! great !
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline zoom74cb
« Reply #20 on: February 05, 2013, 10:25:43 AM »
Thanks Viktor.J  ..When i installed the tri-bar headlight i had to trim a small inside lip of the light where the bulb goes. Because of the indention of the factory bucket, But is simple and does not hurt the headlight in anyway ;D
Offline zoom74cb
« Reply #21 on: March 06, 2013, 08:03:45 AM »
Hello all !!  been working to much..but thought i would share some small updates for the K4 project. Got the valve cover, Chain cover, and upper tree powdercoated so far. fabricated a speedo bracket to bolt on the tree. The speedo should lay flat with the bars. There will be a hole in  the bracket for handle bar wiring to go through eventually. I just mocked the speedo up with the upper tree...So the phillips bolts are not the ones i'm using.
Offline zoom74cb
« Reply #22 on: March 06, 2013, 08:06:12 AM »
pics of powdercoated tree and hand made aluminum speedo bracket
Offline zoom74cb
« Reply #23 on: March 06, 2013, 08:10:15 AM »
more pics of speedo mock up with bracket...The only issue that could be a problem is where the speedo cable hooks up..but it looks like it will be enough room away from the frame neck, so it wont have a tight bend. I think it will turn out awesome.
Offline iron_worker
« Reply #24 on: March 06, 2013, 10:24:49 AM »
Some TLC going into this build.
I like where it's headed so far.
IW
