Author Topic: pics of carbs  (Read 883 times)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
pics of carbs
« on: January 08, 2013, 08:49:28 AM »
can someone post a pic of carb assembly,especially around large return spring next to where cables attach,and also went to take float of 2 carbs that are overfilling but the retaining pin wont come out of any of them is their a trick to it
Offline Johnie
Re: pics of carbs
« Reply #1 on: January 08, 2013, 09:10:50 AM »
Here is the pic of the return spring area on the 750. Click the pic to enlarge it. Regarding those float pins you have to be so careful if they are stuck. If you force it you will break off the pin holder and then you will be looking for another carb. Try using some PB Blaster and let it soak a bit.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline neilc
Re: pics of carbs
« Reply #2 on: January 08, 2013, 11:06:25 AM »
just got float pins out but 3 of the floatneedles that the brass tang makes contact with has no pressure to them and one is solid,which is the correct way?i would think solid
Re: pics of carbs
« Reply #3 on: January 08, 2013, 11:09:28 AM »
 :o  those float needles are internally sprung
they shouldnt be solid OR soft....time for new ones w the rubber tip.
« Last Edit: January 08, 2013, 11:15:04 AM by flybox1 »
Offline neilc
Re: pics of carbs
« Reply #4 on: January 08, 2013, 11:29:23 AM »
do you know where i can get them they are 2.0 for a size
Re: pics of carbs
« Reply #5 on: January 08, 2013, 11:30:55 AM »
what bike?
Offline neilc
Re: pics of carbs
« Reply #6 on: January 08, 2013, 11:58:15 AM »
1971 cb750 k1  they have a 2.0 on them
Re: pics of carbs
« Reply #7 on: January 08, 2013, 12:00:42 PM »
at the bottom.. cut and paste this link
http://www.partsnmore.com/parts/honda/cb750/?filters[category]=carb&filters[fitting]=custom&filters[year]=1971
« Last Edit: January 08, 2013, 12:02:18 PM by flybox1 »
