Logo merchandise is available at the SOHC/4 Shop
does the bike run?
im pretty sure its those tubes.
Pics of the actual carbs would help.
a benefit in having the bowl vent tubes tied together, like balancing vacuum across the rack or something!
I was thinking in Hondaman's book there was a benefit in having the bowl vent tubes tied together, like balancing vacuum across the rack or something!
Quote from: RSchaefer on January 10, 2013, 09:38:19 AMI was thinking in Hondaman's book there was a benefit in having the bowl vent tubes tied together, like balancing vacuum across the rack or something!the 'intention' is to create a slight vacuum inside the bowls, thus raising the fuel level 1-2mm. Its not the carb vent tubes....its the bowl overflow tubes, and they are not tied together. they are routed through holes into the airbox..
