Author Topic: kerker exhaust question  (Read 1984 times)
Offline KRONUS0100
  • MAD MATT THE MANIAC
« on: January 10, 2013, 09:25:52 AM »
750 owners.............if a kerker 4 into 1 is properly fitted to the head..........all the bolt flanges should be equal distance from front face of head right?  took this off my disaster of a 72 motor and put it on the new 78F3 motor, and 1-3 fitt well, number seems to stick out 1/4" further.  yet when i tap it with a long heavy screwdriver and rubber mallett against the flange, i get same heavy thud as i get from other 3.
also, what is recommended gap between oil pan and top of collector?  seems like mine likes to sit at roughly 1/4" clearance.
thanks.................... i know this shouldnt be this hard to install   and it seeems all was same and ok when on the 72 motor
MATT
ccmclane
Re: kerker exhaust question
« Reply #1 on: January 10, 2013, 10:19:48 AM »
Do all of the exhaust ports have the copper gaskets in them?  My first thought was that #4 has one while the others don't.  I didn't know that I had to replace the gaskets whenever removing my Kerkers until recently which is why this came to mind.
Offline KRONUS0100
« Reply #2 on: January 10, 2013, 10:56:30 AM »
yep gaskets in place, getting ready to go out and pull the whole system back off the bike.
MATT
« Reply #3 on: January 10, 2013, 02:18:56 PM »
I think what ccmclane was thinking is that there might be extra crush gaskets on 1, 2 & 3, and none on 4, giving you the extra space on 4.  when i installed a new kerker on my K1 motor,  I had to dig out 2 copper washers from each ex port.  check for extra hidden ones
« Reply #4 on: January 10, 2013, 05:56:47 PM »
I think what ccmclane was thinking is that there might be extra crush gaskets on 1, 2 & 3, and none on 4, giving you the extra space on 4. H
+1. I'll be installing a Kerker on my K5 this weekend.
Offline karnage
« Reply #5 on: January 10, 2013, 07:28:26 PM »
Think its pretty typical of headers.My yosh header did that and my new brocks did the same but they sealed so I didnt worry about it.
Offline KRONUS0100
« Reply #6 on: January 11, 2013, 05:59:53 AM »
welll header is off and found the culprit.  i have a very small ridge out near edge of the #4 port the header was hanging up on.  will make sure to seat #4 pipe before the rest when i go to put it back on.  in meantime i think i can get a wee bit of sand paper on a pencil in there an smooth it down.  interesting i didnt notice it before.
MATT
