Author Topic: silicon rectifer  (Read 724 times)
Offline neil10
silicon rectifer
« on: January 10, 2013, 06:07:49 PM »
Hi, I had some burn wiring so i am gointg to replace complete harness but I beleive the silicon rectifer is the problem when i put test light to the frame of rectifer it lights up is that normal?
Offline neil10
Re: silicon rectifer
« Reply #1 on: January 11, 2013, 12:24:13 AM »
How do you test rectifier
Offline trueblue
« Reply #2 on: January 11, 2013, 12:51:51 AM »
The rectifier is simply 3 diodes, they will pass current one way and not the other.  The regulator in the other hand is a little more involved.  We will need more info, like make and model of the bike, any modifications to said bike, exactly what tests you have done already and results of said tests. ;D
1979 CB650Z
Offline Bodi
« Reply #3 on: January 11, 2013, 05:38:11 AM »
Actually, the 3-phase rectifier has 6 diodes. Testing has been covered here a lot of times but I guess once more won't overload the server.
There are 3 A/C input yellow wires, one positive output red wire, and a ground green wire (or mounting stud/bolt). You need a test meter - analog (moving needle) ohmmeter on the lowest ohms range, a digital multimeter meter with a diode test function, or a test light using 6VDC or more.  Digital ohmmeters are not good for diode testing, you need that diode test function to use a digital meter.
Each diode is a sort of one way valve for electricity.
Each yellow wire has one diode connected pointing to the red wire, and one diode pointing from the ground. With three yellow wires that's 6 diodes total inside the casing.
Worrying about which way they point is not worthwhile, no diode will ever fail by reversing its polarity - and meters vary in their polarity so you can't tell diode direction by which color probe wire is on which end of the diode without checking your meter on a marked diode.
You can do a functional test which is all that's required.
Each yellow wire is tested to both the red wire and to the green ground wire (or stud). With your meter or test light you should have a positive reading (needle deflection, diode test voltage around .6V, or the test light on) with the test leads connected one way around, and no reading (no needle deflection, "ERR", "OPEN" or "INF" on a diode test meter, or light off) with the test leads connected the opposite polarity. That is 12 individual tests: both polarities from yellow to red and both polarities from yellow to ground.
There are two types of diode failure: open and short. Open will give no reading either polarity, short will give a positive reading both polarities (except a diode test meter will show zero volts).
All six diodes must test OK. One bad diode will reduce alternator output. Several bad diodes will probable give you zero alternator output.
Offline trueblue
« Reply #4 on: January 11, 2013, 05:41:00 AM »
Yeah whoops, I meant 3 pairs of diodes ;)
1979 CB650Z
Offline neil10
« Reply #5 on: January 12, 2013, 02:37:08 PM »
When I put test light on  body of rectifier it lights up, does that sound right cb 750 k4 model
« Last Edit: January 12, 2013, 03:10:47 PM by neil10 »
Offline bjbuchanan
« Reply #6 on: January 13, 2013, 10:18:37 AM »
Read the great write up that Bodi posted for you, he made it simple. Unless you just plunk down cash for a new one its time to do work with a meter
