Author Topic: Shortround's New Project ////888cc\\\\  (Read 20582 times)
Offline SHORTROUND
Re: Shortround's New Project ////888cc\\\\ LOL
« Reply #75 on: March 30, 2013, 11:00:51 AM »
I actually found those #s in the archive; but top seal couldn't verify the figment, only that they were their #'s. so I sent the piston in. They didn't even charge me for return shipping. Those guys are really top notch. The rings they gave me were those #'s. i just wanted to be sure.
Offline SHORTROUND
« Reply #76 on: March 30, 2013, 11:07:08 AM »
I'm supposed to be finishing the next episode of seat pan wrapping 101. I however have ellected to sit around the pool drinking instead. Actually I starting to get a little tipsy, so it will have to wait tomorrow. I would probably just end up glueing my fingers to the seat.  :o
Offline SHORTROUND
« Reply #77 on: March 30, 2013, 11:09:48 AM »
I'm also having trouble locating an ostrich; apparently it is not an indigenous species to Florida. But alligator is.............
« Reply #78 on: March 30, 2013, 12:15:39 PM »
I'd bet that ostrich is a little easier or yer ass  :D but gator is tastier and just road kill for you.
Offline Stoli
« Reply #79 on: March 30, 2013, 12:37:47 PM »
http://www.onlinefabricstore.net/vinyl-and-leather/vinyl-and-faux-leather/outdoor-and-marine-vinyl.htm?N=13671+4294963864
They have Ostrich and Emu. I like the Emu better.  They will send you small samples for $1 each, shipping included.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline ivanhoew
« Reply #80 on: March 30, 2013, 12:47:22 PM »
liking this.
just do it .
« Reply #81 on: March 30, 2013, 01:15:10 PM »
http://www.ostriches.org/leather.html
There is an Ostrich farm near Piccacho Peak in southern Arizona right off I-10.
Offline SHORTROUND
« Reply #82 on: March 31, 2013, 06:46:23 AM »
I'm back with part two of Seat Wrapping 101.  I couldn't find an ostrich and alligators are dangerous on both ends and precarious in the middle. Since this is a 101 class I'm going to  use vinyl which is more user friendly.
Materials needed:
Vinyl
Contact cement
Spray adhesive (77)
Heat gun
Do not attempt without a heat gun. You're just gonna work harder for an inferior product. A hairdryer will most likely work. You just want to warm up the vinyl slightly to make it more flexible. NOT HOT; it will tear.
Offline SHORTROUND
« Reply #83 on: March 31, 2013, 06:50:21 AM »
Spray a small amount of spray adhesive on the padding to tack the vinyl in place.
While its getting tacky WARM the vynil. Once again not hot.
Offline SHORTROUND
« Reply #84 on: March 31, 2013, 06:55:36 AM »
Flip it over and apply the contact cement on the bottom of the pan 1/2 - 3/4 of an inch. You won't need much.
Apply cement to the vinyl where it's going to match up.
Notice I'm only doing the flat sides. Don't try and do the entire seat at once. You'll just get cement all over your fingers and make a mess.
Offline SHORTROUND
« Reply #85 on: March 31, 2013, 07:01:54 AM »
Give it about 10 minutes to set up and turn your attention to the front.
Don't forget to warm up the vinyl.
Start at the center and work your way to the edge. The vinyl is going to have a few folds under the pan but don't worry we have ways to deal with it later.
If all goes well you will have something that looks like this...,.
Offline SHORTROUND
« Reply #86 on: March 31, 2013, 08:11:14 AM »
Apply cement to the final backing and let it set up.
Warm up th vinyl ( critical here to make the turn) and continue.
You should end up with something like this.
Offline SHORTROUND
« Reply #87 on: March 31, 2013, 08:13:48 AM »
Remember the folds I mentioned earlier? No worries just cut them out like so. This is very critical when working with leather, ostrich, or velociraptor.
 8) Cheers and Happy Easter
« Last Edit: March 31, 2013, 08:16:45 AM by SHORTROUND »
Offline Vinhead1957
« Reply #88 on: March 31, 2013, 10:01:47 AM »
Excellent !   Very nice I didn't think you could get them out.
Offline SHORTROUND
« Reply #89 on: April 05, 2013, 12:18:32 PM »
Fresh paint
Offline Stoli
« Reply #90 on: April 05, 2013, 01:42:16 PM »
Do you use single stage urethane on the fender and tank like you did with the frame? Can you give me a quick summary of the process you use ... number of coats, sanding between coats, coats of clear...  What kind of paint do you like to use?
My Project Threads:
Offline SHORTROUND
« Reply #91 on: April 05, 2013, 03:06:54 PM »
Last but not least the final stage if seat wrapping 101.  8)
Offline SHORTROUND
« Reply #92 on: April 05, 2013, 04:04:06 PM »
Never try and use single stage on tanks and seats. You can do it but once again you're working harder for an inferior result. When you f&?! it up; and you will if your a beginner, you have to wait 12 hours and repaint the entire thing.
I only use single stage on frames. It cuts out orange peal but most importantly have you ever tried to buff a frame? Me neither and I don't wanna try. I use restoration shop because they have more than 100 colors to choose from and for the $ it can't be beat. Don't listen to the paint snobs; sure there are better paints but they cost a lot more.
Nothing really special about the paint prep. I use kustom shop 2k high build primer. Do not use the duplicolor crap; etching or others, urethane will not adhere to it.  The clear I use is also from kustom shop.
« Last Edit: April 12, 2013, 11:42:56 AM by SHORTROUND »
Offline SHORTROUND
« Reply #93 on: April 06, 2013, 11:30:00 AM »
Paint pics
« Reply #94 on: April 06, 2013, 12:12:19 PM »
Headlamp bucket appears a little Cloudy...  :D ;D
Nice work...
I would want a more cushy seat...I hear the king/queen seats are inexpensive and readily available. ;) ;)
« Reply #95 on: April 06, 2013, 09:27:12 PM »
Very nice as always.
Offline SHORTROUND
« Reply #96 on: April 11, 2013, 07:25:46 PM »
So close. I finished up the rear sets tonight. I just need to finish the levers and polish the points cover. Great, more F&$king sanding.  :(
Offline iron_worker
« Reply #97 on: April 11, 2013, 08:26:03 PM »
Omy! That has a love deep shine to it.  8)
IW
Offline SHORTROUND
« Reply #98 on: April 12, 2013, 11:41:41 AM »
Nice work...
I'm only 5' 4". Comfy seats eat up to much inseam. That's also why I make most seats as narrow as the frame rails.
« Reply #99 on: April 12, 2013, 12:23:54 PM »
Nice work...
Was just kidding, the king/queen seats are looked on with disdain and yield heckling on this forum.
Glad she's come together in time for a little riding and enjoyment.
