Author Topic: O-ring size for 78 CB550 PD46C carbs fuel tubes.  (Read 1004 times)
Offline sweet_baby_james
« on: January 15, 2013, 07:42:30 am »
I'm in the final stages of rebuilding the PD46c carbs from my 78 CB550. The rebuild kit I got didn't come with any replacement o-rings for the aluminum fuel tubes that connect the carbs together. Does anyone know what size these o-rings are?
Also, there are some paper gaskets that separate the carb top from the body; the kit didn't come with these either.  I have a guide for rebuilding the carbs that suggests these can be home-made from thick paper, has anyone done this and found it to be a success?
I'll post pictures soon to make this easier to understand.
Thanks
Offline Deltarider
  • First round...
Re: O-ring size for 78 CB550 PD46C carbs fuel tubes.
« Reply #1 on: January 15, 2013, 07:52:39 am »
What rebuild kit?
The old gaskets between the top and the carb bodies can be used again. No problem.
CB500K2-ED Excel black
Offline wowbagger
  • Not much of an
« Reply #2 on: January 15, 2013, 08:28:25 am »
...that connect the carbs together? That's just fuel line unless you mean the o-rings on the fuel supply T?
« Reply #3 on: January 15, 2013, 08:52:26 am »
The rebuild kit was one I got from Cycle Recycle.  It has the float bowl seals,  the tiny orings, washers and springs for the pilot screws (see picture), and float needles.
I have attached pictures of the aluminum fuel rail tube also.
