Author Topic: float bowl ?  (Read 1816 times)
Offline 78 k550
float bowl ?
« on: July 14, 2006, 07:48:22 PM »
Hey All,
 I started messing with my 76-77 750F and the #4 carb is leaking as soon as I turn the gas on out the little tube on the right.I'm guessing float stuck. So I go to drain the bowl and cant see a drain screw. Well it is pointed in and on the left side of the carb. Should I swap the bowls or just leave them so they stay sealed. I hate braking old seal if I dont have to. Should I just drain it and try to free up the needle by shooting carb cleaner in there? If it doesnt I'll be pulling the bowls. I didn't think you would be able to swap the 2 outside carb bowls.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline flatblack
Re: float bowl ?
« Reply #1 on: July 14, 2006, 08:49:06 PM »
I dunno about your bike, but on some carbs mixing up the float bowls can be a problem...
On my bike (400F), each carb body is numbered (1, 2, 3...) and the bowls should be mounted with the drain plugs to the outside (1 and 2 mounted to the left, 3 and 4 to the right when seated on the bike).
I'd guess they got FUBAR'd at the last carb cleaning and that another carb's bowl has a drain plug facing the wrong way. Then again, you might have a 1 or 2 carb switched to #4.
HTH...
fb
'76 CB400F
'78 CB750K
'04 CBR600F4i
'76 Yamaha RD400C
'79 Yamaha RD400F Daytona Special
'84 Yamaha RZ350
Dirt bikes?  Sure...
Offline 78 k550
Re: float bowl ?
« Reply #2 on: July 14, 2006, 09:07:26 PM »
the PO fubarred it up. On the 2 outer carbs the drain screw are both facing in towards the engine not outward.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78_SaltLick
  • Honda 1974 550
    • Custom Drum making
Re: float bowl ?
« Reply #3 on: July 15, 2006, 07:37:48 AM »
my #1 float bowl does not have a drain screw on it....the other 3 do though. I thought that was strange.
Gold sparkle is the place you outta be.
Offline Bob Wessner
  • "Carbs Suck!"
Re: float bowl ?
« Reply #4 on: July 15, 2006, 08:18:23 AM »
That is odd.  ???
