Author Topic: Tank Emblem Removal  (Read 1748 times)
echilds
Tank Emblem Removal
« on: July 15, 2006, 05:31:03 AM »
Hello all.
Getting ready to strip and repaint my '78 550 tank.  Only two little dings on the tank but the clear coat and pinstripping is in horrible shape.  The bike has been sitting for almost 20 years.  I was quite pleasantly surprised at how clean the inside of the tank was, almost no rust!!!
  I had a question about removing the emblems, did a search and found a good post about removing them.  I just wanted to double check with everyone that they should be held on with just some adhesive and posts correct?
  I just don't want to be prying only to find there is a nut or something.
Thank you all.
Offline Roach Carver
Re: Tank Emblem Removal
« Reply #1 on: July 15, 2006, 08:00:13 AM »
on my 750 they are just pressed on.
Offline Pinhead
  • 1979 CB652-ST
« Reply #2 on: July 15, 2006, 08:16:04 AM »
My 650 has 2 screws on them...
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #3 on: July 15, 2006, 09:40:14 AM »
Using a putty knife, pry between the "H" and "O" and the "D" and "A". That is where the pins are. Alternate back and forth so the emblem doesn't break.
Fonda Honda
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #4 on: July 15, 2006, 04:41:08 PM »
....and be careful to not lose the clips that hold the emblem on.  Also,
it helps to use two skinny tools on opposite sides of the emblem so that
when you pry them off you don't twist the post of the emblem sideways
and break it off. I used two xacto knifes very carefully. A putty knife seems
a bit wide to me.
On many of the old tanks the little clips will be rusted and break off.  They
can be prized out and replaced.....DSS has them.
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
echilds
« Reply #5 on: July 17, 2006, 02:52:59 AM »
Thank you for the tips.  I used a small putty knife, top and bottom, and the emblems popped right off.
  There is nothing like having 100 mechanics at your fingers tips for some great free advice...   ;D   ;D
Offline techy5025
« Reply #6 on: July 17, 2006, 01:44:29 PM »
You're an amateur the first time....that you break something.  The second
time you are a mechanic.  ;D ;D
Jim
2003 CBR600F4I
