one step forward and two steps back.
I replaced the alternator, with a used one, and the system is not charging still.
I performed the test again and found that the RR is faulty!
i did the following:
Stop the engine. Switch the multimeter to DC-Voltage (DCV or Vdc). With the block-connector disconnected
as above, connect the multimeter-leads up to the two extra wires in this connector (apart from the three
YELLOW wires), this in the connector-block emerging from the wiring-loom, not the other side going to the
generator. If there's only one extra wire, connect it to one multimeter-lead and connect the other multimeterlead to the engine-casing. When you switch on the ignition, Check the reading on the display.
I got about 0.4V instead of 12V = RR at fault. Replace it with a new one.
that sucks because it was a new unit.
is there a way to repair it, what could have fried it?
