Author Topic: best way to clean electrical compents?  (Read 1959 times)
Offline ncstatecamp
« on: January 22, 2013, 05:54:55 pm »
What is the best product, house hold preferably, or method to clean electrical stuff like regulators rectifiers etc.
Thanks ahead of time!
Offline goofy3392
Re: best way to clean electrical compents?
« Reply #1 on: January 22, 2013, 06:10:02 pm »
I saw on DCC they used wd-40 to clean the harness.  They dumped a gallon can into a tupperware container and soaked the wires.
Sent from my DROID RAZR using Tapatalk 2
1976 CB550
« Reply #2 on: January 22, 2013, 08:25:20 pm »
For connectors?  Steel wool/Emory cloth, to polish, rubbing alcohol to clean, compressed air to remove any leftover particles, then treat w dielectric grease.
you can go buy electrical contact cleaner for them (deoxit)
For everything else, simple green, brake cleaner
« Last Edit: January 23, 2013, 09:02:20 am by flybox1 »
Offline ncstatecamp
« Reply #3 on: January 23, 2013, 12:37:21 pm »
Brake cleaner really is the best stuff for cleaning anything
Offline lrutt
« Reply #4 on: January 23, 2013, 12:52:15 pm »
And it will be ok for the OP to send you the bill for new switches when the brake cleaner disolves them??? Even some of the contact cleaners of today will raise hell with the plastics in the handlebar switches from these old bikes. I speak from first hand experienc on that. Best to be very gentle with those old parts.
« Reply #5 on: January 23, 2013, 01:05:50 pm »
Wild new concept...
Google search "plastic safe electrical cleaner".
There are lots of chemicals, including brake cleaner and alcohol, that will leach out the plasicizers in certain varieties of plastic and make them brittle, prone to breakage, or dissolve them outright.
Just because it is a clear liquid, does not make it safe to drink, though humans do love to experiment.  ;D
« Reply #6 on: January 23, 2013, 01:10:01 pm »
;D
had no idea they made such specific stuff.  looks like im picking up some Termi-kleen
Offline solo 2
« Reply #7 on: January 23, 2013, 05:22:06 pm »
For the wiring harness, put it in a pillow case and throw it in the washer...when the wifes out ;D. Works great.
You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing left to take away.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #8 on: January 23, 2013, 06:12:41 pm »
Ultrasonic cleaner, then put the components into a pillow case - tie open end - and place into a full laundry dryer under low heat. Stuff comes out of the bag like new. Dont tell my wife. Then after looking over your harness...greeeeez the ever living out of it. wait what components are we talking about? I am referencing the harness.
Offline nccb
  • 1974 CB750 Four
« Reply #9 on: January 23, 2013, 06:44:19 pm »
I had a similar question a while back with some bad connectors, check this thread out:
http://forums.sohc4.net/index.php?topic=113099.msg1272854#msg1272854
madmtnmotors post should go into the how-to's for that
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #10 on: January 23, 2013, 07:53:07 pm »
Impressive!
Offline Fritz
« Reply #11 on: January 24, 2013, 02:34:01 am »
To remove oxides from contacts, I use glass fibre pencils. For cases, wires, etc. just soap and water :)
1976 CB550F
Offline wowbagger
  • Not much of an
« Reply #12 on: January 24, 2013, 07:07:11 am »
