Well, after a brief hiatus I am back tinkering with the 550. Doesn't look too good for having it ride-able for the Barber Festival, but I will keep plugging away. Good stuff is happening so I do not want to rush things (ha, progress is anything but a rush on this build!
My dad purchased a titled bike so we could putts around the back roads legally, but it had a pretty good leak at the cylinder base. I spent a few minutes here and there tearing down the top end and got it back up and going within a couple weeks. This guy is in pretty good condition, its a keeper.
Small projects like the above, redoing my S90 wheels, and that funny thing called life has put the 550 on the back burner for a bit. I did at least start the 550 about every week, just to keep it fresh.
Now enough excuses about why I have been slacking on the 550 and on to some updates...
I found out that I was running all the carbs reaaaalllly lean. So I set them to all about 1.5 turns out, and it seems much better now. After that I synced them up and its running really smooth now. Good throttle response and good idle. I'm not sure if I need to be tweaking the air screws though. I can't distinguish any change when adjusting them.
I splurged and got a Slipstream Cycle rear set kit. Quality seams very good. I will have to tinker with placement as my modified F exhaust causes some clearance issues. The rear sets are designed to mount at the passenger pegs, which I have done for the time being. I think I will end up moving them forward about 3" in the future for a better riding position and better foot angle. I think slightly higher and swept back bars will help as well. My current ones were just in a pile of parts that came with a previous bike. My exhaust is limiting the downward angle of the brake lever, and moving it forward will also give me more clearance to angle it down.
I'm also thinking about painting the linkages and frames black (not the knurled parts). I think it stands out a bit too much for my liking.
After I got them fitted up today I took it for a spin and it was incredible. It felt so good to wind through the gears for the first time. I got a few strange looks in the neighborhood but its all good. I would probably do the same if somebody was riding by with a Simple Green bottle as a fuel tank... It pulled very well, not stutter at all and will go faster than I'm comfortable with right now
. I was very uncomfortable when I started riding, but I settled in after a while and became more comfortable with the riding position. I do think moving the rear sets forward are needed though.
Next order of business is to figure out my tank situation. With help from you guys, I have identified the tank that I picked as a CB450T.
And, as mentioned before, the petcock definitely has clearance issues with the carbs. I do not have the petcock to go with it.
Here is my plan... please chime in with recommendations/harassment
I would like to relocate the petcock somewhere forward of the current location to provide clearance. I've scoped this guy out on 4-1.com
http://4into1.com/honda-fuel-valve-petcock-16-x-1-5mm-16950-292-000-cb350-cb360-cb450/Now it says its for a 350/360/450, but I think it should work? Now here is the hard part...
The mounting threads are 16 x 1.5. And of course, I can't find a weld-in bung to match. I'm hoping one of our resident machinists could hook me up and make one!?!?! I think something like this is what I will need -->
http://www.summitracing.com/parts/sum-220062/overview/ , but in steel so it can be welded in.
Thoughts or directions?
Appreciate those who will make it through the entire post
