Author Topic: CB750A Performance Mods  (Read 36055 times)
Offline stevematic
Re: CB750A Performance Mods
« Reply #50 on: November 28, 2016, 05:36:46 AM »
This is my first time posting on this site. After recently swapping K carbs onto my A, I would like to contribute. When changing carbs, not only do you need the same boots, you also need the same cables. K carbs require K throttle cables. Most suppliers list this as a difference between years (70-76 vs 77-78)
Offline TurboD
« Reply #51 on: November 28, 2016, 06:11:56 AM »
Yes you will need to use the earlier K boots and cable(s).
« Reply #52 on: August 30, 2017, 07:34:14 PM »
I'm thinking all the A's used the -392 head from the 75/76 CB750F. Therefore the spigots are the early head size spigots.
You're right about the Casting, Jerry, but they did almost no port work, probably due to the smaller carbs being present. The heads can pick up LOTS of flow with some simple port work on the "A" bikes I have done. This, plus 836 (CruisinImage) pistons, a nice K cam, and think about swapping in one of the spark advancers from either the F1-2 or K7-8, or maybe a K4-5 with slightly tighter advancer springs, will brighten these up. The stock advancer is the "333" model from the CB350F, but with heavier springs.
Link to website: SOHC4shop.com  (Note: no longer at www.SOHC4shop.com, moved off WWW. in 2024).
Offline fireman1073
« Reply #53 on: September 22, 2017, 02:27:45 PM »
i have a 76a motor and a 75k and the pistons and heads appear identical
the 750a has less compression?
is this combustion chamber size or pistons because i plan to use the 750a top end (pistons, jug and head) on a 750k I'm building with a k cam
the cams are different from my rough measurements as the k has more lift and/or duration correct?
Steve
« Last Edit: June 18, 2019, 05:21:27 PM by raymond10078 »
« Reply #54 on: October 01, 2017, 08:08:13 PM »
someone local has a 78 750a with title, stored indoors and presently not running asking 800 need gone asap so maybe cheaper
here you go---> https://southcoast.craigslist.org/mcy/d/1978-honda-750/6313442841.html
Steve
The "A" has the -392- (bigger chamber) head, but with -300- type pistons, and about 20 degrees less cam duration. This makes compression about 8.8:1 or so.
Offline stikman
  • Bit of an
« Reply #55 on: October 14, 2017, 04:36:16 PM »
The A cam also has about .015" less lift on both in and exh than a mid 70s K cam.  And I believe that's even at the lobe not the valve.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
« Reply #56 on: October 14, 2017, 07:20:09 PM »
Yeah, that's about what I measured, too. A good K cam or F cam can quickly perk it up. Since it only has the two speeds, I'd lean toward the F cams for hiway use, the K cams for in-town perking-up work.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #57 on: March 31, 2018, 07:45:26 PM »
A fellow brought in a set of CB750A carbs to the shop today, and they were small compared to the CB750 PD series... I believe they were PD44's? The slides were about the same as the CB550 PD 46 carbs, and I wasn't sure if the PD44's were the stock CB750A carbs. They did have the accelerator pump, and a bracket which might have had the idle solenoid on it at one time, but was bare and flopping around.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline stikman
  • Bit of an
« Reply #58 on: April 11, 2018, 10:36:15 AM »
Charlie
Yep, you're corrrect.  PD44's are stock CB750A carbs.
Offline tscott
« Reply #59 on: November 26, 2019, 08:18:52 AM »
Purchasing a K cam right now that doesn't have the chain drive (sprocket) attached... that should be fine right? I can use the chain drive (sprocket) off my A cam and put it on my new K cam correct?
Also, I see some jetting options for the K roundtops, but I took JWeeks advice and went with the Seca/Maxim/XJ650 CV carbs (32mm vs. the 28mm K and 24mm A carbs). I can't find any info on what kind of main jet rework this may need... anybody have any experience with the S/M/XJ650 carbs and jetting? (Will email Jon again also)
Currently planning to put a K cam in but may run the new carbs without the cam swap to begin.
Any advice would be welcome.
Thanks,
Toran
« Last Edit: November 26, 2019, 09:03:10 AM by tscott »
« Reply #60 on: May 27, 2025, 05:37:51 AM »
This is a very old thread but a very important point has never been addressed, The single limiting factor in building a powerful A is the small primary drive HyVo chain and the lack of a tensioner for that chain. Honda corrected this with the DOHC engines.
Online Don R
« Reply #61 on: June 04, 2025, 05:36:53 AM »
 When the CV chains go bad, do they get noisy, rub grooves in the case or break? Or all the above?
  I remember reading about a turbocharged drag Hondamatic that would pull the front wheel down track when it shifted to high gear. I bet that was a wild ride. I can't help wondering if there is a newer better-quality chain that would fit. Like our new 530 drive chains are so much better than the old ones.
« Last Edit: June 04, 2025, 05:41:11 AM by Don R »
