Author Topic: 1972 cb350f cafe build  (Read 23863 times)
Offline SONIC
    • Walnut Wood Works
Re: 1972 cb350f cafe build
« Reply #25 on: April 02, 2013, 08:28:15 PM »
Looking good man!
I'm going to go ahead and be that dick that says it...but those pods are junk. They are going to make for a tuning Nightmare, and with the open exhaust, you'll never make it run right...
Offline Nick0
« Reply #26 on: April 02, 2013, 08:39:14 PM »
Front brake lever came in the mail, picked up a universal bleeder valve from Napa. I top off the resivour with fluid and bled the air out of the lines and had front the front brakes working, rode for a couple hours and they functioned beautifully. Came out to go for a ride the next day and front brakes stick first time I use them, I tried opening the bleeder valve and checking to make sure the fluid return hole isn't clogged. The fluid return wasn't clogged and opening the bleeder valve did nothing so I tore the caliper apart cleaned and lubed everything and put It all back together there was corrosion that was preventing the piston from moving freely and once I cleaned that all out and put
It back together it all worked again.
Offline Nick0
« Reply #27 on: April 02, 2013, 08:45:50 PM »
Ignition switch came in the mail, plugged it in and got everything wired up. Electrical system is now functional and seems to be recharging as it should.
Offline Nick0
« Reply #28 on: April 02, 2013, 08:51:33 PM »
Laid fiberglass over my seat mold, seat turned out pretty cool. I still need to trim away some of the extra fiberglass (about two inches around the bottom and front), lay down another layer, and sand it all smooth but I am pleased with the overall shape.
Offline Nick0
« Reply #29 on: April 02, 2013, 08:56:10 PM »
Side covers came in the mail
Offline Nick0
« Reply #30 on: April 02, 2013, 09:05:48 PM »
Got lots of new parts in, cut my plug wires off a couple inches outside the coil housing striped the wires and soldered in new accel plug wires to replace the old hard and cracked ones. The hardened core of my old wire wasn't holding the screw in type plug caps as it should. New NGK resistor plug caps, looks a lot better and it's nice to not have to worry as much about cracking a brittle plug wire when working on other things. started the bike up and it's running  great
Offline Nick0
« Reply #31 on: April 02, 2013, 09:09:18 PM »
Polished stator cover, next piece I'm going to polish when I get a chance is the oil pump/front sprocket cover.
Offline Nick0
« Reply #32 on: April 02, 2013, 09:12:58 PM »
Started to grind off all the brackets on the frame, cut the tail section of the frame and welded in a cafe hoop. Still need to go back and clean up my welds but the hoop Is solid and holds the weight of the bike.
Offline Nick0
« Reply #33 on: April 02, 2013, 09:15:55 PM »
As she sits now, school starting back up  tomorrow.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #34 on: April 03, 2013, 09:55:40 AM »
Where did you order the fork boots from?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Nick0
« Reply #35 on: April 03, 2013, 10:49:14 AM »
found them at cyclexchange.net
look under "frame and front end", it's item number FR-14.  good quality stuff, $29 shipped.
Offline zeek
« Reply #36 on: April 03, 2013, 07:22:28 PM »
Looks like your making realy good progress on  that thing. I like where it's headed.
Offline Nick0
« Reply #37 on: April 03, 2013, 07:25:05 PM »
Thanks for the feedback guys.
Offline Nick0
« Reply #38 on: April 15, 2013, 11:43:46 AM »
Attached my cafe seat today, cut all brackets off the frame then welded four threaded plugs onto the rails to use as mounting points for my seat, these are the threaded pieces I used
Offline Nick0
« Reply #39 on: April 15, 2013, 11:50:16 AM »
Cut the fiberglass seat down some flatted out the bottom and front, then traced it on a 1" thick board and cut out a seat pan.
Offline Nick0
« Reply #40 on: April 15, 2013, 11:56:14 AM »
Filed the hump in the back of the speed with foam
Offline Nick0
« Reply #41 on: April 15, 2013, 12:02:32 PM »
Glued seat pan into fiberglass form[img width=600
Offline Nick0
« Reply #42 on: April 15, 2013, 12:33:01 PM »
Lined the seat up and drilled holes through to match up with the threaded plugs, put some tapered head flush mount type bolts through the seat then through a 1/4 inch rubber washer between the wooden seat pan and the frame mounts and tightened It down. still need to drill two more holes towards the back of the seat, right before the hump to put last two bots, Seat Is very solid.
Offline Nick0
« Reply #43 on: April 15, 2013, 12:34:16 PM »
Offline Nick0
« Reply #44 on: May 06, 2013, 04:32:13 AM »
Reset all my valve clearances this weekend, finished wrapping and painting my headers, and began to modify a cb360 tank to fit my bike
Offline Nick0
« Reply #45 on: May 06, 2013, 04:37:38 AM »
Polished left side engine cover
Offline The Mayor
  • My Gallery
« Reply #46 on: July 16, 2013, 09:31:23 PM »
Nice build. I've got a '72 I'm finishing up, and would love to hear more on how your tuning is going. I've ditched the airbox for pods (for now) and want to run a more open exhaust. Also have 85 mains, left the stock 35 pilots. What kind of adjustments have you had to make? Is it a pain to cold start?
http://forums.sohc4.net/index.php?topic=121088.msg1371628#msg1371628
Offline Nick0
« Reply #47 on: February 23, 2014, 06:20:03 PM »
well, life got busy as it sometimes does and with school and a job my project got pushed off to the side for awhile but i have recently dove back into it.  :D so when I last updated this thread the bike was fully functional but quite ugly. I have since taken everything apart to be cleaned/painted/polished. I think modifying the cb360 tank is going to be more trouble than it is worth and I really want to get this thing back on the road so I am abandoning the idea of modifying it for my bike.
Offline Nick0
« Reply #48 on: February 23, 2014, 09:42:28 PM »
so here is the frame after disassembly, sandblasting, and primer. I used dupli-color liquid auto body primer and a small gravity fed kobalt spray gun from lowes and was quite pleased with the results.
Offline Nick0
« Reply #49 on: February 23, 2014, 09:48:18 PM »
and here is the frame after several coats of red
