Author Topic: Weird drilled disc question  (Read 3393 times)
Offline Scott S
« on: January 29, 2013, 03:51:27 PM »
 Is there an actual function to the direction of the slots or holes on a drilled rotor? Should the sweep or arc be facing forward or backwards (CW or CCW)? Or is it purely aesthetics?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Xnavylfr
Re: Weird drilled disc question
« Reply #1 on: January 29, 2013, 04:40:40 PM »
I don't think it has to have a PATTERN! The reason they are drilled is to help remove some water from floating on the disc and causing them from HYDRO-PLANING in a sense.
Xnavylfr(CHUCK)
Offline Scott S
« Reply #2 on: January 29, 2013, 04:59:03 PM »
 Right, I understand all that. I just wondered if there was a "backwards" and "forwards" or Left and Right, etc.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #3 on: January 29, 2013, 05:17:40 PM »
 To clarify: I'm talking about when there's a pattern, like this for example.
'71 CB500 K0
'81 Yamaha XS650
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #4 on: January 29, 2013, 06:20:39 PM »
I believe the rotation should go forward.  For example, the rotor on the left (in your pic) would go on the right hand side and the other on the left hand side.
Offline Thousandson
  • Ride, Fix, Repeat
« Reply #5 on: January 29, 2013, 07:31:34 PM »
I have heard other wise. I talked to one shop owner he said CW.  I also drilled my disks like this.
Current ride: 78' Cb750F
Offline Cabilao
  • Diving and Driving
    • Sea-Explorers Watersport
« Reply #6 on: January 30, 2013, 12:00:25 AM »
It doesnt matter cw or ccw. the holes help you to get rid of water much quicker and helps also with cooling the disks if used on the race track or on long rides downhill when a lot of braking is needed. Normal disks tend to fading and drilled ones not. Dirt is also removed faster and some people say the pads last longer. dont know bout this. But drilled rotors in combination with braided hoses should improve the brakes.
just my 2 cents.
before:
Kreidler RMC(50cc)
CB400N(first bike)
RD350LC(more than one)
XS850(great bike)
CB900F(wish i still have it)
FZR1000(too fast)
Rickman CR900(sold for a good price)
now:
Rusi 125
CB 125 CL(just for fun)
Yamaha XTZ 125
CB750P7(mystery bike)
77/78 cool 2 member
Offline wvshooter
« Reply #7 on: January 30, 2013, 09:01:15 AM »
As far as function is concerned the pattern doesn't matter. What you want it to look like after it's finished does matter. If you like it, it's ok.
Two things you don't want to do. Don't use too many holes or such large holes that the rotor won't be able to stay straight or will become too weak. Also, don't drill holes in a way that will cause your wheel to become unbalanced. In other words, too many holes on one half of the rotor and too few holes on the other half.
Offline TS250
« Reply #8 on: January 30, 2013, 09:14:05 AM »
Pattern direction doesn't matter at all.  The holes help with brake action in wet conditions, and lightening the rotor (unsprung weight).  They don't help much at all with brake fade; I've had horrendous fade on a drilled single rotor (with steel line) 550 going downhill.  Dual discs help with fade, or at least extending the time it takes to heat the rotor/pad/fluid enough to fade.
One could make an argument that a drilled single rotor will fade quicker than a non-drilled rotor.  Less mass takes less time to heat.
Offline Viktor.J
  • Breaking in the forum
« Reply #9 on: January 30, 2013, 09:41:45 AM »
And many holes makes a bigger area for heat transfer. BUT Whether the new heat transfer area affects more then the decreased volume and therefor easier convection I don't know. Think you'll have to run some simulations and different cases to be really sure.
(Bigger heat transfer area > decreased convection or Bigger heat transfer area < decreased convection)
(hope you understand what I mean, English is not my mother tounge)
To answer the question: No, it doesn't matter if you made them identical. Is a wheel harder to spin clockwise or counter clockwise ? The wheel ( a circle) doesn't have a end, therefor no beginning, therefor no front or back ;) ( you still have rotation direction on tires and such)
« Last Edit: January 30, 2013, 09:45:15 AM by Viktor.J »
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline TS250
« Reply #10 on: January 30, 2013, 09:51:54 AM »
Oh for sure more surface area decreases cooling time.  They'll still heat up faster.  It's a compromise.
Offline zoolion
« Reply #11 on: January 30, 2013, 10:02:47 AM »
I'm pretty sure the holes are to vent gasses created during the braking process that are released as the pad material wears. The layer of gas between the rotor and pad reduces friction, pad rides on a cushion of air. I think water gets boiled off pretty quickly, although the steam created could contribute to the gas effect.
I may be mistaken and this may only apply to carbon racing brakes.
« Reply #12 on: January 30, 2013, 06:44:16 PM »
Ever notice how high performance race cars [F1] do not have drilled rotors?
Offline Thousandson
  • Ride, Fix, Repeat
« Reply #13 on: January 30, 2013, 07:26:44 PM »
F1, and many others cars, including most commuter vehicles, don't have drilled disks. But they do have vented holes running in between two flat disks. More interrupted surface area = Less braking power.
Offline alancop
  • Vroom, vroom!
  • Vroom, vroom!
« Reply #14 on: January 30, 2013, 07:34:49 PM »
In the world of autoX sometimes rotors are drilled and the holes are lightly filed in order to make them bite into the pad, giving you a massive amount of braking power, however this also wears the pads insanely fast, like 1 set per 3 or 4 runs.
It's almost twice as old as me, I don't know how the hell it works!
Offline Viktor.J
« Reply #15 on: January 31, 2013, 02:38:22 AM »
as mentioned disc for cars are already "ventilated". But however, take a look at the superbike bikes, all of them have drilled holes .... must be some reason:)
Honda CB750 K2
Offline cb650
« Reply #16 on: January 31, 2013, 06:33:17 AM »
Also the "super cars" are carbon fiber and replaced frequently.
Offline TS250
« Reply #17 on: January 31, 2013, 06:53:05 AM »
With the exception of the top-of-the-line MotoGP bikes.  Their carbon rotors aren't drilled.  ;)
Offline Viktor.J
« Reply #18 on: January 31, 2013, 07:07:53 AM »
I know ! But still they can make a disc of what they want :)
Superbikes dont, right ? Wonder why they drill, if Any racingrider know th
at would be great !
Honda CB750 K2
Offline Scott S
« Reply #19 on: January 31, 2013, 08:29:24 AM »
 This wasn't really a question of WHAT the holes do or don't do....kinda got a grasp of that. I was just wondering if the DIRECTION of the holes/pattern has an effect. Apparently, No. Which is good: Now I can run one on each of my CB's! :)
'71 CB500 K0
'81 Yamaha XS650
« Reply #20 on: February 01, 2013, 04:19:58 AM »
Scott - just curious, why are you doing it?
Offline Harsh
« Reply #21 on: February 01, 2013, 06:20:13 AM »
Well looking at my Triumph (that came with drilled rotors) my previous reply in regards to direction is incorrect.  I also looked at my buddies GSXR and SV, both of them follow how my Triumph is.  I don't know if it makes a difference or not, but manufacturers appear to do it that way so I would pressume there is a reason for it.
Offline Scott S
« Reply #22 on: February 01, 2013, 04:34:33 PM »
 Becuase I'm sick of trying to get the RH side of my dual disc conversion to work properly. Three master cylinders, two different brands of pads, two different calipers, shims, spacers, grinding, alignment, etc.
 I either have very spongy, weak brakes, or the RH side drags. I can NOT get it straightened out. I'm going back to one disc and will use the other drilled disc on another bike.
'71 CB500 K0
'81 Yamaha XS650
Offline wvshooter
« Reply #23 on: February 02, 2013, 10:10:00 AM »
Sorry to hear about your problem. Sometimes things just blow up in your face.
I'm kind of old fashion, being old myself, but I like the "look" of the single rotor on the cb's. And as far as braking power goes who want's to lock up a tire anyway?
