Author Topic: installing blinker help  (Read 1425 times)
Offline txterror
« on: February 01, 2013, 09:51:32 PM »
Ok guys once again i need yalls help please. Bike didnt com with blinkers so im trying to install som minis. Need help on where to hook up wires. Also what type of signal relay can i get from auto store to work with these. In second pic you can see where po cut 2green wires from the rear wires for some reason. Im assuming i will need to splice these, correct? Last pic is of signal light wires
1975 cb400f
Offline txterror
Re: installing blinker help
« Reply #1 on: February 01, 2013, 09:55:08 PM »
Pic of lights
1975 cb400f
Offline 74750k4
« Reply #2 on: February 01, 2013, 11:33:26 PM »
Take a look at the wiring diagram for your particular year/model bike. We don't know what that is.
That will show you what color coded wires. the blinkers, and flasher used to be connected to...   before your PO started removing/cutting things.
Get yourself some 3.5mm bullets so you don't cut anything else.
Offline txterror
« Reply #3 on: February 01, 2013, 11:58:36 PM »
First pic is head light wires. Second pic is wires at rear and third are the two wires from blinker. In first post. Was just hopung someone could point out wires in headlight that blinkers need to connect to.
1975 cb400f
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #4 on: February 02, 2013, 03:02:00 AM »
Oldmanhonda.com for wiring schematic.  If those are led tailights you'll need a blinker winker flasher made for those.  The cheap little resistance type won't work, not enough current flow with led.  All the project bikes i have done have had the wires tucked nearby the original location.  Orange and blue as i vaguely remember......
Offline LesterPiglet
  • 1977 CB550F2
« Reply #5 on: February 02, 2013, 03:39:02 AM »
orange and light blue are for indicators.
bollingball
« Reply #6 on: February 02, 2013, 04:17:50 AM »
Orange is for LEFT Blue is for  RIGHT
You need a ground for all four.
Ken
Offline txterror
« Reply #7 on: February 02, 2013, 07:09:47 AM »
Thanks guys. Lights arent led's.. What about the relay from auto store, which one should i look for
1975 cb400f
Offline bjbuchanan
« Reply #8 on: February 02, 2013, 08:04:23 AM »
I think 554. Its a two prong flasher. If you search top left there is a ton of options like heavy duty and otgers with part #'s
Offline txterror
« Reply #9 on: February 02, 2013, 08:41:08 AM »
Two prong flasher is fine even if i hav 3 wires
1975 cb400f
Offline txterror
« Reply #10 on: February 02, 2013, 09:08:12 AM »
Also guys how important is this ground wire that connects to headlight bucket bolts. Has em on both sides. Nut doesnt fit new bolt. Or can i just hack those bolts off and resolder to new bolts or some kinda clip
1975 cb400f
Offline Vinhead1957
« Reply #11 on: February 02, 2013, 10:00:42 AM »
It would be easier to use a crimp terminal as an extra washer
Offline bjbuchanan
« Reply #12 on: February 02, 2013, 11:54:41 AM »
the bolts with the ground there are because the stock signals ground thru their body so you would need them. with your aftermarket ones they will have a ground wire, most likely at least so now the old grounds are superfluous
You can use a three prong flasher it just has a dedicated ground wire and you would have to ground that in order to use it. grey goes to one terminal, black to another with the two prong and if you use a third the ground lug
Just remember that the way you are gonna run your turn signals up front that it supports your headlight now so you want a nice solid mount so it isn't buzzy
If you mean the turn signals themselves have three wires then you have front running lights. You connect the running light function to the orange/white and blue/white that comes from the handlebars. The regular turn signal lights go to solid light blue and solid orange and then ground those suckers. You will prob have the extra ground spots in the bucket at one of those junctions
Offline txterror
« Reply #13 on: February 03, 2013, 03:06:43 PM »
Got em workin guys thanks for the help. Headlight bucket is a lil wobbly now because bolts are a lil thinner than original bolts. So im gona have to find a solution for that now but blinkers work. Thanks again
1975 cb400f
Offline bjbuchanan
« Reply #14 on: February 03, 2013, 06:01:41 PM »
I use those like 10.95 emgo headlight brackets with the three holes. Not stunning but my fork ears were rusted crap to begin with. The back hole with a nice washer will hold the signals and the front most hole secures the headlight nicely
Offline txterror
« Reply #15 on: February 03, 2013, 08:57:57 PM »
Cool ill give it a go. Thanks
1975 cb400f
Offline txterror
« Reply #16 on: February 06, 2013, 12:56:27 PM »
success! lights are on and functioning
1975 cb400f
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
« Reply #17 on: February 07, 2013, 04:54:16 PM »
don't forget directionals in the state of mass have to be a certain distance apart from the center of the headlight,i think its like 8"
Offline txterror
« Reply #18 on: February 08, 2013, 07:54:47 AM »
thanks but i live in the lone star state (TX)
1975 cb400f
Offline neilc
« Reply #19 on: February 08, 2013, 11:22:33 AM »
lucky,massachusetts bites they regulate everything for a buck,gotta move soon
