Author Topic: CB750 early crank cases  (Read 1244 times)
Offline ttr400
    • ttr400 Projects and Billet parts.
« on: July 17, 2006, 12:03:42 PM »
I have a set of 69 -70? cb750 NOS crank cases, how do i figure out what year these might be? they are unstamped and are painted a light grey colour. were the cases on all years painted from the factory?
many thanks
Kevin.
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Re: CB750 early crank cases
« Reply #1 on: July 18, 2006, 08:02:28 AM »
Yep all painted but supposedly silver. VERY early cases had a different number of clutch cover bolts but I aint up enough on the 750's to say how many or when
Offline ttr400
« Reply #2 on: July 18, 2006, 09:26:02 AM »
Thanks for the info, I had a closer look at the colour which could be silver but not very gloss.
Ok all you 750 guys, how many bolts on your clutch covers? and model year.
Thanks Kevin
www.ttr400.com
Sterling2
« Reply #3 on: July 18, 2006, 01:52:27 PM »
 Sandcast cases have 9 bolts in the clutch cover. Diecast cases all have 10.  Real early sandcast cases also have the month and day cast into them.  If you have a set with no serial numbers and it does not appear that the numbers were ground off, they are most likely a set of diecast cases made in 1970 used by a dealer on a warranty claim.
Offline Clyde
« Reply #4 on: July 18, 2006, 06:16:34 PM »
The size of breather/oil return on the back of the crankcase changed in later cases (74?) to a larger size.
K7/K8/F2/F3 used a bigger output shaft bearing.
Honda put an extra bolt on the post sand cast cases due to a supposed oil weeping problem
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
