Author Topic: Alternator Up Grade 32amps  (Read 99519 times)
Re: Alternator Up Grade 32amps
« Reply #250 on: January 11, 2014, 09:08:24 PM »
Need a kick start approach to the 500/550 alt replacement to inject funding into the r&d ?
$100 investment yields $50-75 off the system for the first 10 donors?
Maybe?
Offline Lostboy Steve
« Reply #251 on: January 13, 2014, 12:09:26 PM »
Anders if you do a kickstarter project I'll fund. I desperately need some more juice on my 77 550.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #252 on: January 13, 2014, 01:02:03 PM »
Just rode home from NH this evening after picking up my CB750K4 that had been left with Anders for the alternator upgrade. Bike started up easily, headlight seemed to be superbright even at idle (no dimming) but maybe that was just because it was 9pm and dark! Rode the 74 miles home at a good pace and the bike felt smooth and very responsive  -this would be due to the newly cleaned carbs no doubt ;)
Anyway looking forward to the Fall when I can run heated gloves and heated jacket and not have to worry about running out of juice. Photos of the setup to follow...
thanks Anders! Very professional setup and as always quality workmanship!
cheers
Andy
OK Andy, calendar is "at press" so that check box is checked off. So, now other than the family commitments and other things to catch up on...we know you had outfitted your bike with the wiring for the heated gear and we all know it's been plenty cold (shut-up ARiZONAns and TEXans and CALIFORNIAns who enjoy the warmth consistently year round) ((boy I miss AZ even the high desert I was at ~5000ft))
So, how about a report on the heated gear and your enjoyment of the 750 with that nice charging system?  Might help inspire some of us...and make others of us wishing we had it available on the 500/550.
I have a higher output used stator for my CX500 when I take the time to pull the motor and check the timing chains and replace the main and oil and water pump seal (what we call a triple bypass on the CX motor). I have the Ignitech upgrade for the CDI to replace the stock CDI and it doesn't need the highspeed and low speed coils so I can get away with the stator upgrade to allow me to have enough Amperage to spare for heated gear. The Ti ignition bikes had higher output stators allowing the use of some heated gear, early CXs do not.
Unfortunately, we don't have a bolt in replacement for the CB500/CB550 yet.
So, I understand heated jackets but where do you need the heat in the pants.  Normally the seat and back of my legs get coldest when outside just working in cold weather. Riding it is similar I have found. With the riding position you wouldn't want heat where your legs are bending at the back of the knee and the front are going to have more exposure unless you have a big fairing with lowers to hide behind...
David
« Reply #253 on: January 13, 2014, 02:15:05 PM »
Let me tell you for me at least its fingers (hands), toes (feet) more the digits than the rest, and my knees. My knees go numb very quickly and then become uncomfortable.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline ncstatecamp
« Reply #254 on: January 13, 2014, 04:04:43 PM »
So I'm trying to look through this thread but not finding the answers I want. I understand the set ups been tested. is it available for purchase yet, and what's the price lookin like?
Re: Altenator Up Grade 32amps
« Reply #255 on: January 13, 2014, 04:42:53 PM »
You didn't look real hard, Yes its been tested, yes its being sold and yes it works...  Price below.... ;D
It's those damn pods, Mike. ;)
He's not running stock carbs.... :P
Any idea on price for this kit yet..?
      Hi Retro Rocket,
  It look like the kit will be $625.00 puls shipping. I have over 3500 miles on one and it works great.
Offline ncstatecamp
« Reply #256 on: January 13, 2014, 04:44:18 PM »
      Hi Retro Rocket,
On my phone so it's a pain in the ass a bit. But thank you!
If I can ask another stupid question, what all is included in the kit?
« Last Edit: January 13, 2014, 04:45:56 PM by ncstatecamp »
Offline anders288
« Reply #257 on: January 13, 2014, 05:47:48 PM »
  Hi
The kit comes with stator,
                            stator mount
                            stator mount bolts
                            flywheel ,
                            crankshaft taper adapter
                            Crankshaft bolt spacer
                            regulator
                            Pem studs to mount regulator
                            New regulator connector plugs
                            Battery terminals
                            Wire
                            Also offer free installation
« Reply #258 on: January 13, 2014, 06:42:44 PM »
David
David and others
Yes I bought Anders alternator upgrade and like Anders have a few thousand miles on it. Not only is it great for heated gear (for me Gerbing jacket liner and Gerbing gloves) it has 13V at idle! Battery starts right up every time!
Here are my leads to attach heated gear -
And the First Gear dual heat troller
Riding in cold (so far 15 -32F) is now pretty easy and no longer get that tired fatigued feeling after a cold winter days ride. Warm and toasty the whole time making me more alert and not shivering thinking about how Ill warm my gloves up on the cylinder block when I stop (done that for years!). I ride in all weathers and have been winter riding for 20 years. As soon as Anders had this bolt in kit I jumped on it - I mean how many times can you buy precisely machined parts for a 40 year old bike!? Something that will fit right in, make your bike easier to start and give you a range of options in running heated gear or other electrical accessories (if thats what you like). Lucky for me Anders is only 1 hr away and is workmanship is second to none. The guy literally lives and breathes SOHC. He has been doing this since these bikes were new!! Anders is Mr Quality when it comes to machining and knowing SOHCs! Sort of like what MikeR is to SOHC engine building!!   8)
If you like to ride when its cold but dont want to bundle up under many layers and want to remain alert when riding in the cold and like to have you bike start easier and run better then this alt upgrade is for you! Make the investment you wont regret it!!
cheers
Andy
« Reply #259 on: January 13, 2014, 11:48:48 PM »
thats great with the free install offer!
Offline K_Kalynuik
« Reply #260 on: January 14, 2014, 07:58:41 AM »
  Would love to see this happen for the 550. I could help donate R&D money as well if it meant getting a better charging system in my 550.
78' CB592 - http://forums.sohc4.net/index.php?topic=121580.0
1996 Ducati 900ss
1983 Kawasaki GPz750 Track bike
Offline DM500K0
« Reply #261 on: January 15, 2014, 06:04:33 PM »
Maybe?
Sounds like a good deal all around.
Offline mjstone
  • I'm definitly not a
« Reply #262 on: January 22, 2014, 04:40:05 PM »
-13F this for this mornings ride to work!  A new personal record for me.  It sure would be nice to have more heated stuff to use besides my Cabellas heated gloves, that run on their own batteries.  What could we do to get this up and rolling for the 500/550s?
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline anders288
« Reply #263 on: January 22, 2014, 06:00:17 PM »
MJ
      -13 is way to cold for me. If we can get ten 550 guys that are willing to commit to buy one at $600 I will design and prototype a kit. My guess would be around six weeks until prototype is ready for testing. So the next thing would be to start a list of guys that want one.
Offline bambuhiphop
« Reply #264 on: January 23, 2014, 08:46:37 AM »
I will put my name down for a system. I unfortunately cannot help with the prototyping as my bike is still in pieces but I think this thing is so killer that I would love to see it on my bike when it is done.
« Reply #265 on: January 23, 2014, 09:47:04 AM »
I am unable to commit as I've been out of work for about 16 months, were I able I would be in line.
David
Offline K_Kalynuik
« Reply #266 on: January 23, 2014, 11:02:56 AM »
MJ
Anders, Im in, 100%. 1978 CB550. - I hope others follow.
1996 Ducati 900ss
« Reply #267 on: January 23, 2014, 11:21:36 AM »
itll be the same unit for any 500 engines,not only 550s.
Offline Jerilee
« Reply #268 on: January 23, 2014, 11:57:08 AM »
Anders, have you thought about making another thread, or website to sell the kits you do make? This is the thread that pops up first and foremost when we search for Alternator upgrades and solutions. Thanks for all the hard work you've put into these things by the way, I'll be saving my pennies for a kit of my own. : )
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline anders288
« Reply #269 on: January 23, 2014, 03:56:27 PM »
                 Hi Jerilee,
       I live in Candia,NH. I don't understand the search thing. I don't do making websites I'm just an old motorhead.
Offline Jerilee
« Reply #270 on: January 23, 2014, 05:32:58 PM »
Fair enough!  :)
I'm up in Manchester, by the way. I'm sure to run into you one of these days.
Jeri~
77/78 cool 2 member
« Reply #271 on: January 23, 2014, 05:47:22 PM »
                 Hi Jerilee,
Spoken (or written) like an old motorhead. ;) There is a reason I don't have a website and my oldest son could have one done very quickly. ;D ;D
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #272 on: January 23, 2014, 08:05:29 PM »
I just posted a message here that my rotor is farked on the 77 cb550k that I thought was "almost done.." ha ha.
So yes, please put me down for one of your systems. In the meantime, I am gonna look for a solid used one to get by.
I am also finishing a 73cb500k for a friend and I would guess he'd be interested as well (price dependent).
Thanks.
s
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline anders288
« Reply #273 on: January 24, 2014, 05:54:45 PM »
       Hi everone,
  It looks like we have 3 people wanting a kit so far.   bambuhiphop
        K_Kalynuik
        my bad sorry
        alacrity
   not a bad start.
        Anders
« Last Edit: January 25, 2014, 04:09:01 AM by anders288 »
« Reply #274 on: January 24, 2014, 09:01:07 PM »
Thanks.
s
i dont want one anders,take my name off,i dont know where that came from?your rotor is fine alacrity.
« Last Edit: January 24, 2014, 09:04:09 PM by dave500 »
