Author Topic: Alternator Up Grade 32amps  (Read 99042 times)
Re: Alternator Up Grade 32amps
« Reply #375 on: January 15, 2017, 12:07:07 PM »
Definitely IN for a 550 kit!!
Offline anders288
« Reply #376 on: January 15, 2017, 12:22:37 PM »
  Hi Bert I will be making extra kits and will put your name on one.
        Anders
Offline bert96
  • past ride
« Reply #377 on: January 15, 2017, 12:25:26 PM »
Great
I can give a deposit if you want.
Let me know
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
« Reply #378 on: January 15, 2017, 12:26:36 PM »
Is anyone near New Hampshire that owns a 550 that Anders can borrow to develop the 550 upgrade kit?
Offline anders288
« Reply #379 on: January 15, 2017, 12:31:57 PM »
  Hi Bert,
  No need for a deposit being an old man your word is enough.
Offline bert96
  • past ride
« Reply #380 on: January 15, 2017, 12:34:39 PM »
Ok,but i just wanted to show that i'm serious.
Just pm me when ready!
Thanks
Bert
Offline anders288
« Reply #381 on: January 15, 2017, 12:45:02 PM »
   OK will pm you and post here also.
Offline bambuhiphop
« Reply #382 on: January 15, 2017, 12:46:27 PM »
I'd absolutely be IN for a 550 kit as well!
Offline Desert-SOHC
  • It's old
« Reply #383 on: January 15, 2017, 01:03:00 PM »
Thanks...NOW I have to save up some cash for another upgrade fro Mable!   :D
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline flatlander
« Reply #384 on: January 15, 2017, 01:15:22 PM »
anders, sorry to hear about your health troubles. once you're up on your feet again... i'm in for a 550 kit.
Offline anders288
« Reply #385 on: January 15, 2017, 01:22:45 PM »
Just so everyone is clear the 750 and 550 are very different the 750 kit is designed and works great I have sold many of them. The 550 needs to be designed and tested. I own a fleet of 750 and never owned a 550 I need to get one so I can measure it and design a kit. The last time I took a pole of people that wanted 550 kits I thinks there was something less than six interested.
 One piece of 4"aluminum rod is over $600.00.  The system that  fantino posted may not do well at lower RPM.
Offline calj737
  • I refuse...
« Reply #386 on: January 15, 2017, 01:27:04 PM »
Glad you've recovered and back on your way to good health.
Where are you buying your metal from, Anders? $600 for 4" 6061 seems REALLY HIGH. As for a 550 system to have as a development, what all would you need? I can perhaps provide you the components to help you along.
Offline fantino
« Reply #387 on: January 15, 2017, 01:32:41 PM »
Agreed. It's definitely aimed more at HiPo/race use. Probably not ideal for regular use in traffic.
Offline anders288
« Reply #388 on: January 15, 2017, 01:36:04 PM »
  Hi calj737,
 I'm in NH have operated my machine shop from 1989 what does 4" 6061 cost where you are? I need a complete bike to measure then test I would never sell a kit without testing it.
there are some around New England  I should be able to find one.
Offline timbo750
« Reply #389 on: January 15, 2017, 02:16:30 PM »
I'm still interested in a 750 kit.
« Reply #390 on: January 15, 2017, 03:21:39 PM »
Understood!
Hey Cal, I wonder if GV would be willing to let Anders borrow one of his 550s.
Offline fantino
« Reply #391 on: January 15, 2017, 03:30:27 PM »
  Hi calj737,
I can't speak for Cal, but I'm in Seattle and at the ThyssenKrupp warehouse by my work an 8ft length of hot finish 6061 4" round is $350, cold finish is $600. This is for will-call pickup. Delivery adds up really quick with pieces that heavy, I imagine.
Offline anders288
« Reply #392 on: January 15, 2017, 03:47:02 PM »
   I would go any where in New England if I could find it for $350.
« Reply #393 on: January 15, 2017, 06:02:41 PM »
I never heard of hot and cold finish Al.....sounds like maybe steel.
 We usually pay 3.5- 4.5 per pound and a length would be 12ft..
 Off to check weight...... 185 lbs for 12 feet.
« Last Edit: January 15, 2017, 06:06:14 PM by 754 »
Offline calj737
  • I refuse...
« Reply #394 on: January 15, 2017, 06:35:08 PM »
Anders - check here:
https://www.metalsupermarkets.com/bostonnorth/#AboutUs
They sell anything in "any size". You don't need to be 8', or 12' if you only need 27" (as an example). I bought a 42"x60"x3/8" plate of 6061 for under $500. A 4'x6'x5/8" plate of cold rolled for less than $400. I haven't bought 4" aluminum stock from them, but I know it won't be expensive unless you're ordering in 12'-20'.
Offline fantino
« Reply #395 on: January 15, 2017, 06:47:26 PM »
Hot is just regular ol' extrusion. Cold finish gets drawn through rollers to relieve internal stress, has better crack/fatigue resistance and tighter tolerances. I think 6061-T6 becomes T651 when it's cold worked, but most places I've bought material from just call it cold finished or cold drawn.
Offline anders288
« Reply #396 on: January 15, 2017, 06:52:48 PM »
  All the 6061 I've bought has been extruded 10-12 feet long.
Offline calj737
  • I refuse...
« Reply #397 on: January 15, 2017, 06:56:10 PM »
I know a local motorcycle shop that buys large rolls of 6061 (6", 8" and 9" diameter) and has them pre-cut into discs, and delivered for machining. He does this all through the local Metal SuperMarket and finds their pricing better than others.
If you don't need 10'-12' at a time, they can be a great source for you. (Okay, disclaimer: I really want you to get going a 550 system  ;))
« Reply #398 on: January 15, 2017, 07:15:26 PM »
I always like to have some 4inch around for wheel spacers, adapters, etc.... I usually get 1-2 feet at a time..
 If you get under a length though, then price per pound goes up...
And how much you buy every year affects your pricing.
« Reply #399 on: January 15, 2017, 07:58:27 PM »
Me too!!   ;)
