Author Topic: CB750 camshaft and cam tower interchangeability  (Read 1191 times)
Offline Cruzader
« on: February 07, 2013, 02:47:08 PM »
Hey all,
I have a 1970 CB750 K1 with a trashed camshaft and ruined cam towers/rockers. Can I use parts from a donor 1975 cb750?
Thanks in advance
« Last Edit: February 07, 2013, 02:48:55 PM by Cruzader »
Re: CB750 camshaft and cam tower interchangeability
« Reply #1 on: February 07, 2013, 07:18:35 PM »
Yes
 There may ba a plugged oil hole, fix that or ruin another cam.
Offline Cruzader
« Reply #2 on: February 07, 2013, 08:48:51 PM »
Yes
Great, thanks!
Yeah I checked the oil passages and they all look clear, but the cam and rockers on cylinder #4 were completely dry when I tore the motor down.
« Reply #3 on: February 07, 2013, 10:49:18 PM »
If one side was dry there IS a blockage somewhere
Offline Cruzader
« Reply #4 on: February 08, 2013, 09:24:49 AM »
Yeah, I believe so. The passages look clear though. I'm thinking it may be the oil pump. The oil pump screen was also covered in metal shavings so suction/oil pressure could not have been optimal.
« Reply #5 on: February 08, 2013, 09:40:40 AM »
IF one side is dry, say 3-4 and the other is wet, 1-2, its not the oil pump. the 2 sides are fed from the same main feed from the pump. That feed splits under the cylinder and shoots up the rear studs on either side of the cam chain tunnel. The blockage usualy occurs at the orifice from the head to the cam tower. The block, usually debris froma prior overhaul, has it been worked on before you?, is forced up by oil pressure into the orifice and closes off the hole. It is possible that when the pressur relents, the plug drops back down the stud/oil passage. Waiting to be pushed back up into the hole once the pressure comes back.
Personal experience here and from many posters on the forum. This is not unique, happens a lot.
AS to your question the parts will interchange. But the later parts will have places for screws the K0 did not have. Ignore them.
Offline bruzer59
  • 1977 CB 750F
« Reply #6 on: February 08, 2013, 02:15:27 PM »
DOUBBLE CHECK THE OIL PORTS IN THE HEAD & IN THE CAM TOWERS ,,,COMPRESSED AIR IS YOUR FRIEND
Offline bjbuchanan
« Reply #7 on: February 08, 2013, 02:36:53 PM »
Super excited to help^^    :P
