Author Topic: Galvanising fuell tank.  (Read 1047 times)
Offline cb650PK
« on: February 07, 2013, 02:51:32 PM »
We all know the struggles with the ethanol laced gas and tank coatings. Has anyone investigated the possibility of galvanising the inside of  tank?
S CB750 na vecne casy a nikdy jinak.
Offline CycleRanger
  • No comment about being an
Re: Galvanising fuel tank.
« Reply #1 on: February 07, 2013, 02:57:14 PM »
I believe the fuel and additives may react with the zinc and end up in the combustion chambers and environment.
Offline BeSeeingYou
Re: Galvanising fuell tank.
« Reply #2 on: February 07, 2013, 06:55:16 PM »
+1...don't do it.
Offline cb650PK
« Reply #3 on: February 07, 2013, 09:11:59 PM »
I have no concern about ethanol reacting with zinc any more then it reacting with steel. I was interested in what it would actually take to galvanise the inside of the tank and thought perhaps someone with home zinc plating experience may have an idea.
Offline crazypj
  • I'm brill, me
« Reply #4 on: February 07, 2013, 09:20:19 PM »
There were several experiments with zinc when lead was removed from gas, don't remember what happened?
Offline phil71
« Reply #5 on: February 07, 2013, 10:33:29 PM »
There is no good reason to galvanize a gas tank.
Offline crazypj
  • I'm brill, me
« Reply #6 on: February 08, 2013, 07:36:00 AM »
There is if you can  ;)
Offline totty
« Reply #7 on: February 08, 2013, 08:19:42 AM »
I'd like the outside galvanized then lacquered, fresh galv with the flake patterns that appear looks great. I've just never gotten around to trying it and distortion is a concern.
Offline Bru-tom
« Reply #8 on: February 08, 2013, 08:31:44 AM »
well, thats called hot dipping right? its a messy way of zinc plating. im having my parts electro galvanised. much neater and a nice finish, mush like glavanised bolts you buy..
but i think which ever way you do it, it will get into the tank...if thats what you're fine with happening.
Offline rhinoracer
« Reply #9 on: February 09, 2013, 10:14:19 PM »
Takes some nasty chemicals to galvanize, not worth it in my opinion. Also paint won't stick to galvanizing on the outside.
Baja native.
Offline Bru-tom
« Reply #10 on: February 10, 2013, 12:02:20 AM »
paint will stick mate, just need to use an etch primer.
