Author Topic: Runs rough after top end rebuild.  (Read 5759 times)
croquesaveur
Re: Runs rough after top end rebuild.
« Reply #25 on: July 21, 2006, 08:06:24 PM »
I already had a compression tester (that I had bought at Canadian Tire a few years ago).  All I needed was the 12mm adapter.  That's why I was reluctant to go to Canadian Tire because I'd have to buy a whole new tester to get the adapter.
For other Canadians (and presumably Americans too) NAPA sells 12mm compresision tester adapters for about $13.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #26 on: July 21, 2006, 08:34:34 PM »
Do the 12mm adaptors thread onto a 14mm?  I might need one for the leak-down tester I'm planning on buying.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
croquesaveur
« Reply #27 on: July 21, 2006, 09:57:57 PM »
Yes.
