Greetings. I am working on a CB550 with a production date of 8/74, so I am assuming it is a 1975 model. I am trying to time the ignition points, but I cant get either set to begin opening at the f mark. I am using the instructions per the manual, which are not very clear. The manual says to disconnect the blue wire from the 1.4 set, then connect the test light at that point with the key on. It doesnt specify to connect the test light to the blue wire or the post on the points where the blue wire was. The diagram isnt very clear, but it does show the other end of the test light going to ground. When I turn the key on, the blue wire is hot all the time, so I connected the test light to the post on the points and the other end of the test light to ground. I could not get any reading with the light connected that way, so I connected the test light to the battery+ and the other end to the post on the points, and when the points start to open, the light lights up. The problem is that the points are begining to open about halfway between the f mark and the first advance mark, and there is not enough adjustment on the plate to line it up with the f mark. I have removed the advancer and it is working as it shoud. I really dont know what the problem is and was hoping that someone here would know. Thank you.
