Author Topic: CB650 pilot screw o-ring/washer  (Read 2003 times)
iszekeres
« on: July 18, 2006, 08:30:22 AM »
Just removed/cleaned the carbs on my 79 650, and noticed none of the pilot screws have their washer and o-ring installed.  I was wondering if anyone knew what sizes the washer and o-ring were, and if it was possible to get a pair for each carb without purchasing the entire gasket kit.....
Any help would be appreciated!
--ian
Offline crazypj
  • I'm brill, me
Re: CB650 pilot screw o-ring/washer
« Reply #1 on: July 18, 2006, 08:45:29 AM »
Dont know if Honda sells them individually but Suzuki use the same sizes as far as I know and they do.
 Dont know if this is for the 'o' ring or washer but if you can find a Suzuki dealer and give him this part number you can then get the other parts you need
13295-26E00
Should be able to work out what bike its for and check on microfiche or computer.
PJ
iszekeres
« Reply #2 on: July 18, 2006, 11:27:13 AM »
I will give that part number a try and see how it works out....if anyone has a set of four o-rings and washers unused from a carb rebuild I would be happy to buy them.....
Thanks!
--ian
gasguzler
« Reply #3 on: July 18, 2006, 12:57:59 PM »
I purchased one pilot screw with o-ring from a dealer recently, ('79 CB650 as well) so I know for a fact that you order them without the whole carb kit. I will check my old bills tonight to see if I cant get a part #.
