Author Topic: 75 CB400f Massive restoration and Cafe project.  (Read 32265 times)
Offline Godffery
  • Godffery's Garage
Re: 75 CB400f Massive restoration and Cafe project.
« Reply #125 on: December 08, 2015, 06:38:00 PM »
 That's a Good Caliper!
Not too hard to mount ether.  You could use that with one of my Drilled & Thinned rotors, mounted to the stock hub.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/Brake+Rotors+_+Thinned+and+Drilled/HONDA+Front+brake+rotors+CB+350K-350F-360-400F/
Offline straat-toe
  • Everybody knows about the bird.
« Reply #126 on: December 08, 2015, 10:14:40 PM »
Ok Thomas, you have my interest. Will it clear the spokes? Share a pic with me of the left hand Caliper please. And the Guzzi! Godffery, I'll think about the Disc, the Rand to Dollar exchange rate is so crazy at the moment that I have to choose my Purchases carefully.(and I am soon to be self employed  ;D)
Put the selectors and drum in last night and the crank in the top half. With the tensioner in place. Once I'm done with the bottom end I'm planning on getting the pistons coated with the good #$%*.
 http://www.powerkote.co.za/Products.html
No School, No Job, No Worries.
Offline Godffery
  • Godffery's Garage
« Reply #127 on: December 09, 2015, 11:48:38 PM »
That is a valid point I had not considered!
Offline straat-toe
« Reply #128 on: December 10, 2015, 12:02:53 AM »
Yeah South Africa is on the point to become the next Greece. Screw politics, this is about bikes!
Offline 01Thomas
« Reply #129 on: December 10, 2015, 12:33:15 PM »
OK, I'll take some photos of the calipers over the next few days and send them along.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline straat-toe
« Reply #130 on: July 10, 2016, 06:28:58 AM »
Thread back from the dead! Again.
Slow and steady wins the race they say. So after looking for a alternate caliper for the 400 I decided to stick with the stock one. I have a phenolic piston from Godffery's Garage and will be using a braided hose. After doing the same upgrade to my 550 I can say it's all you need to improve the braking.
I finally closed up my cases and installed my new piston rings. Valve lapping and Cylinder head next then.
So that's all new seals and primary and cam chains and some new rings.
Slow and steady indeed.
Offline charlatan
  • Faster than summer fruit through a short granny!
    • Build blog
« Reply #131 on: July 10, 2016, 08:07:42 AM »
Looking good!
My 550's getting there slowly as well. Almost ready to fire it up after the rebuild. Problem with taking so long is that I had to clean the carbs all over again... and now the float bowl gaskets have swollen.  >:(
« Last Edit: July 10, 2016, 08:10:28 AM by charlatan »
Offline straat-toe
« Reply #132 on: July 10, 2016, 10:16:40 PM »
Yeah.
I find it hard to believe how long this has taken me when i look at some other builds on this forum.
Time to start burning rubber.
Offline charlatan
    • Build blog
« Reply #133 on: July 10, 2016, 11:10:31 PM »
Yeah.
Hell yeah. I'll start with those rubber float bowl o-rings!
Offline marting100
« Reply #134 on: July 11, 2016, 01:25:51 PM »
Nice work!!
M
Offline straat-toe
« Reply #135 on: July 11, 2016, 01:44:19 PM »
Thanks.
Offline charlatan
    • Build blog
« Reply #136 on: July 11, 2016, 02:28:40 PM »
Just noticed something when I studied your photos more closely: I used probably a tenth the amount of sealant you have there when I joined my cases because I'm paranoid about the stuff breaking off and clogging up an oil passage. I suspect that's what happened to my parts bike... I bought it seized, and there's bits of some kind of red gasket material everywhere inside.
I'm no expert and I don't want to cause unnecessary pain, but I'd get a second opinion on that. Would be much cheaper to redo the sealant now than seizing the motor. But then maybe I'm just paranoid.
Offline straat-toe
« Reply #137 on: July 11, 2016, 08:41:30 PM »
HI Charl.
Thanks for the concern. It's one of mine too. I learnt that on my 550 build. So the bead follows the outside edge of the cases pretty closely. So if it's glooping out it does it on the outside not the inside.
Paranoia made me split my 550 cases again to make sure of it. I checked the inside of the 400 as best as I could with a light from the sump and the conrod openings. It looked ok. ;)
Offline charlatan
    • Build blog
« Reply #138 on: July 11, 2016, 09:49:45 PM »
OK, good
Offline straat-toe
« Reply #139 on: July 11, 2016, 10:16:27 PM »
I'm trying not to freak out now. I'm going to take another look in from the sump.
Offline charlatan
    • Build blog
« Reply #140 on: July 11, 2016, 10:58:22 PM »
LOL... And now I'm worried I used too little! Argh. Start a support group?
Offline straat-toe
« Reply #141 on: July 11, 2016, 11:45:13 PM »
Possibly.
Offline straat-toe
« Reply #142 on: August 08, 2016, 12:21:05 PM »
OK. So in between life an the 550s I have managed to spend some more time with the 400.
I Did some valve lapping and installed the valves with the new seals. All new rubbers in the oil channel bits and jets. I even managed a quick mock up before mocking it down again.
And tonight I installed my cam and cam chain. Timing marks lined up with the top-O-the-head.
Once the engine is buttoned up its on to wheel truing and getting the frame ready to drop this engine in.....I know I've said this at least 10 times over the last 3 years...
Offline charlatan
    • Build blog
« Reply #143 on: August 09, 2016, 01:35:00 AM »
Looking awesome! Hou die blink kant bo!
(Got my 550 started this weekend, btw. )
Can you PM me your cell number? I'd love to come and check it out some time. Or just to chat on whatsapp.
Offline Leonardovans
  • Live to ride, ride to live!
« Reply #144 on: August 09, 2016, 04:37:25 AM »
Netjies. Ek het nog nie eers begin met myne nie.
My rides:
1972 Honda CB750K2 - To be restored
1975 Honda CB400 Four Supersport - Supertramp - Cafe-resto in progress
1976 Honda Cb400 Four Supersport - Running well, needs TLC.
1978 Honda CX500 Cafe Racer - The Freeburger - Completed
1979 Honda CX500 - Cafe Racer build in progress.
1983 Honda CX500 - Mono shock cafe build in progress.
1984 Honda XL200R - Restoration
1989 Kawasaki KDX200 - Restoration
Offline straat-toe
« Reply #145 on: August 09, 2016, 12:08:22 PM »
Done Charlaton. En Leo. Ek het darem net een ;)
« Last Edit: August 09, 2016, 12:10:15 PM by straat-toe »
« Reply #146 on: August 09, 2016, 12:21:52 PM »
Maar jy het die 550 ook. Ek het nou die dag vir my n CB750K2 gekry. Moet hom ook nog bou.
My rides:
Offline straat-toe
« Reply #147 on: August 09, 2016, 12:34:18 PM »
Next on the list.
