Author Topic: how much $$ for a mint 75 CB750 F0  (Read 2118 times)
qcextreme
« on: May 15, 2005, 06:03:52 PM »
found a mint 75 CB750 F0 all Original how much should I pay??
Offline Gordon
  • 750K1, 550K2
Re: how much $$ for a mint 75 CB750 F0
« Reply #1 on: May 15, 2005, 06:25:38 PM »
However much it's worth to you.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: May 15, 2005, 06:38:56 PM »
What does 'mint' mean?  Original low mileage never restored?  Or perfectly rebuilt/refinished like-new restoration?
If it's cosmetically and mechanically perfect, $2000 wouldn't be unreasonable.  I bought a '76 CB550F for $350 and will break $1,700 in total costs in the next two weeks - of that only $500 is labour from my mechanic.  The other $1,200 is new parts and boring the cylinders for new pistons/rings.
The advantage I have is I know exactly what is on/in my bike.  Any bike can be made to look nice.  Make sure everything is as it should be - compression check, hear it run cold and hot - any idle loping?  If it is mint and working perfectly, like I say, $2000 isn't a bad deal (in my books).
If you can get it for less and it's perfect, and you LOVE it (don't settle if you had your heart set on a 500 or a different model for example) then buy it.
Let's see pics!
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
« Reply #3 on: May 16, 2005, 02:19:02 AM »
Not the most sought after model its worth whatever you want to pay
Mikeshonda750F
« Reply #4 on: May 16, 2005, 03:48:00 AM »
Paied 350 for my F0 (i think it was 350) Had been sitting outside under a tarp for several years, but after some good cleaning its in great condition.. 6k on the clock.. factory paint is flawless.. spent probably 200$ in cleaning supplies/tune up parts/shop materials. Was offered 1200 for it last summer. I paied 500 for my K6 750 and had less than desired results.
Offline Geeto67
  • A grumpy
« Reply #5 on: May 16, 2005, 06:52:51 AM »
I payed $800 for my 1975 K5 CB750 a couple of years ago. It was in very clean original shape (no rust, minimal fading on paint, all parts there except speedo), I wouldn't say mint but it is better than 80% of the k5's I have seen in the last few years. I would say if you really want it $2000 is on the high side but still not totaly unreasonable. If you end up paying between $1000 and $1500 I'd say you did good.
Maintenance Matters Most
