Author Topic: 73 CB750 Project Bike - HONCATI  (Read 2896 times)
Offline TexasTwister250
  • "Effort doesn't count...Only Results"
« on: February 13, 2013, 03:09:03 PM »
Getting close to running on project bike #1, I decided to start another project bike.  This one will use Ducati suspension on the front and rear and have the oil tank in the tail as on project bike #1.  Here is a pic after I ebayed the frame, engine, tank, then cleaned up the engine and installed in into the frame, added a header and new set of 29mm CR's, added levers and hooked up the front Brembos.  I pretty much had the suspension wheels and brakes from leftovers after building my Ducati 748 track bike, last I slapped on a new set of tires.  Here is where I am at with it....
« Last Edit: February 13, 2013, 03:39:18 PM by TexasTwister250 »
73 CB750 cafe
73 CB750 project cafe
01 Duc 748s Trackbike
04 RC51
07 Ducati 1098
46 Indian Chief
Past Rides:  08 Busa, 00' Honda RS250, 05' VMax, 85' Ninja 900, 86' Ninja 600, 83' GPZ750, 84' Ninja 900, 82' Seca 750, 77' YZ400, 81'Virago 750, Honda Enduro 250, 73' Yamaha DT-175
Offline Mcwilliams570
Re: 73 CB750 Project Bike - HONCATI
« Reply #1 on: February 13, 2013, 03:58:22 PM »
Looks good I like the stance that it has. The tail section seems a bit high probally just me. Will be watching this one.
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
« Reply #2 on: February 13, 2013, 07:16:28 PM »
WOW that is wild looking and in a good way!  Stock motor?
« Reply #3 on: February 13, 2013, 07:34:05 PM »
Mcwilliams570 - it looks higher in the back because it is on the rear stand, but the Ducati rear suspension is height adjustable, so it can be fine tuned.
Steve-o, thanks.  I bought the motor off eBay from a dismantler so im not sure of the mods. However from an examination under the valve cover it looks like it very recently had a valve job, and the compression is around 210 on all 4 cylinders, so I'm thinking it might have a big bore kit, but I have to assume it is stock.  I'm not looking for extreame performance if it will pass the ton I will be happy.  :)
73 CB750 cafe
04 RC51
07 Ducati 1098
46 Indian Chief
Offline USCG_C130
« Reply #4 on: November 26, 2013, 11:26:23 AM »
Any update on this build?  I was hoping to see something!
Offline Greg H
  • When two cams is one too many .
  • Still crazy after all these years .
« Reply #5 on: November 30, 2013, 03:12:55 AM »
I really like the look of this 8) .Any bike which incorporates anything Ducati in the build gets my attention .  One of the first specials I ever built was a Tricati , a 500 Triumph twin motor in a Ducati 200 Elite rolling chassis . It seemed like a good idea at the time  ::)
« Last Edit: November 30, 2013, 03:15:50 AM by Greg H »
Offline dummy
« Reply #6 on: November 30, 2013, 07:00:20 AM »
For the most part that thing looks sick but in my opinion that swing arm is hideous.  Im sure you are using parts you already have but I personally think one of the tressle swing arms would fit perfectly with the rest of the frame. Not that your trying to spend your life savings to make a bike I think is pretty.  The rest of the bike looks like it will be fantastic though.
« Reply #7 on: August 11, 2014, 08:13:54 PM »
Finally got the bike running... Next will be paint, headlight and seat.  We will be at Barber in a couple of months, it should be finished by then.
« Last Edit: August 11, 2014, 09:00:57 PM by TexasTwister250 »
73 CB750 cafe
04 RC51
07 Ducati 1098
46 Indian Chief
Offline Trad
« Reply #8 on: August 11, 2014, 09:27:23 PM »
That's wild looking.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline albertaboy
  • No way I'm a
« Reply #9 on: August 11, 2014, 10:03:44 PM »
Cool. I like it!!! :)
1975 CB750K
No where to go and all day to get there.
My build thread: http://forums.sohc4.net/index.php?topic=131424.0
