Author Topic: anyone tried a 37T rear sprocket on a CB750  (Read 1592 times)
Offline Scott
  • 72 CB750
« on: February 13, 2013, 11:12:27 PM »
G'day
I've got a CB750 and was about to put on the 37 tooth rear sprocket that I ordered, it doesn't look like the gaurd (is that what you call it) that goes on after the sprocket but before the lock tabs and nuts will fit as it is a larger diameter than the sprocket.
Is it cool to run with out this gaurd thing over the sprocket?
I don't have a 530 chain to suit the new sprocket yet so I haven't bothered putting the wheel back on yet.
Thanks for any thoughts
Scott
Offline Dream750
Re: anyone tried a 37T rear sprocket on a CB750
« Reply #1 on: February 13, 2013, 11:46:42 PM »
How about using the smaller K0 and K1 sprocket plate? These were used up to frame number: CB750-1026845. The photo shows one installed on a 45T sprocket and would probably fit your 37T sprocket. The original part number is: 41211-300-000
Offline Scott
  • 72 CB750
« Reply #2 on: February 14, 2013, 12:03:51 AM »
I reckon that's a great idea.
I've just had a quick look and can't find any on ebay, but I'll keep looking
Thanks
Offline brandEn
« Reply #3 on: February 14, 2013, 12:20:29 AM »
You're okay to run without that guard most people just throw them in the bin.
Offline Scott
  • 72 CB750
« Reply #4 on: February 14, 2013, 12:41:22 AM »
cheers
the thing I'm wondering now.
Is the 530 chain too wide compared to the 520 chain or is it the same width and just the link size is different
« Reply #5 on: February 14, 2013, 04:42:35 AM »
What size front sprocket are you going with, with the 37t back ?
Offline lucky
« Reply #6 on: February 14, 2013, 07:08:23 AM »
We would have to know what YEAR your CB750 is to give you the correct information.
« Reply #7 on: February 14, 2013, 07:55:28 AM »
 Hope you never have to ride in town, and you will probably not use fifth gear much,, that is tall gearing..
Offline Scott
  • 72 CB750
« Reply #8 on: February 14, 2013, 12:21:43 PM »
Hi
Thanks for reading my post
The front sprocket I have a choice of 17 or 18 I have them both but haven't put one on yet
The bike is a 72 model
As for the tall gearing I don't ride the bike around town much as I have a different bike for that.  But I am thinking of making the CB750 my everyday bike so maybe I won't put this rear sprocket on as I don't have a chain to suit that sprocket anyway.
The front sprocket will take a 520 chain while the rear srocket needs a 530 I currently have a 520 waiting to be installed and a 45 rear but I was curious to try the 37
Scott
« Reply #9 on: February 14, 2013, 01:34:53 PM »
As 754 mentioned that gearing sounds way too tall.Sounds like some clutch slipping would be in order for takeoff. Betcha one of our math guys has a formula to transpose that to real world comparisons.
« Last Edit: February 14, 2013, 01:36:24 PM by ekpent »
« Reply #10 on: February 14, 2013, 01:50:53 PM »
Dude, pretty sure you got the wrong sprocket.  37 tooth is for a 550. Stock for a 750 is 48(depending on year) :o  With a 37t, I don't think you will ever even be able to get into 5th gear or even get moving from a stop, for that matter...if you want low revs on the freeway try an 18t front and 46t rear.  Do a search here to find tons of threads on what has worked for others
Offline Cougars750F0
« Reply #11 on: February 14, 2013, 03:32:27 PM »
Not to hi jack this thread but while the professionals are looking I would like to squeeze a questin in. My apologies and thanks in advance for any help. I have a 18 front and rear 43 on a 1975 750FO the bike has the factory close gearing and I have not had it freeway speeds yet. I this a good fit? I'm also trying to find out if this has been changed or is it the way it came originally. I haven't had it up to speed yet because it still has the origanal tires on it. I will be changing them asap. Thanks again.
« Last Edit: February 15, 2013, 11:43:49 AM by Cougars750F »
1970 Honda / Yoshimura 810 with ported head, 1968  Honda CB450 5 speed European model, 1973  Triumph Bonneville 750 twin carburetor model, 1975 Honda 750F0 Super Sport, 1977 Honda 750A
« Reply #12 on: February 14, 2013, 03:59:51 PM »
+1000000
I see a burned out clutch in your immediate future....  That gearing is silly high..... :o
Offline Scott
  • 72 CB750
« Reply #13 on: February 14, 2013, 09:31:04 PM »
I got that 37T from Cycle X after seeing it on their web site.
I went out to see a mate today and he ordered me a 40T and a 45T between those two and my 17T and 18T front I should be able to find a gearing that is OK.
I'm about to put in a new clutch as well so I don't want to burn it out too soon.
The last one got stuffed when I tried to get all the smoke out of my rear tyre to make it safe to change
Scott
« Reply #14 on: February 15, 2013, 05:02:02 AM »
You never did say what year it is but most guys like the 17/48,I just run the stock 18/48.
Offline 74750k4
« Reply #15 on: February 15, 2013, 11:14:29 AM »
+1 on 17/48... nice off take, and torque coming out of twisties.
Offline Scott
  • 72 CB750
« Reply #16 on: February 15, 2013, 11:19:08 AM »
It's a 72 model.
The gearing that the bike had on it was 17/45 and it used to rev it's tits off riding at about 140km (about 90mph) I don't know the exact revs cause the tacho doesn't work.
Scott
