Author Topic: Will these work on my 1975 CB550?  (Read 898 times)
Offline hellraiserDLX
« on: February 14, 2013, 03:37:11 PM »
First of all I don't know the difference between the 550K, or F or T or whatever else is out there. I have a 1975 CB550 and I wanted to know if these would fit. The fork seals themselves are fine, so I didn't want to buy a complete kit. And if anyone can help me identify what model my bike is I would appreciate it. (I know I'm a typical noob)  ;D
http://www.ebay.com/itm/EMGO-POLISHED-ALUMINUM-HEAD-LIGHT-MOUNTS-FIT-35-39-41MM-FORKS-/160951902214?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D5557667183843196020%26pid%3D100015%26prg%3D1006%26rk%3D5%26sd%3D261164466046%26
Offline Scott S
Re: Will these work on my 1975 CB550?
« Reply #1 on: February 14, 2013, 05:45:05 PM »
 Yes, they will fit but you have to use the supplied shims. You should have 35mm forks.
 Going by the side covers, it looks like you have a 550"K" model, but the header looks like an "F" model. Post your VIN number. A shot of the RH side of the bike, specifically around the kicker/foot pegs, would also help ID your bike.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: February 14, 2013, 06:03:59 PM »
You will have to remove the stock fork ears to use those.  When you do you will probably find a lot of rust on the upper fork tube, not a problem other than appearance.  Welcome, the manual can be downloaded from this forum if you do not have one...Larry
« Reply #3 on: February 14, 2013, 06:47:46 PM »
CB550K, but with an F exhaust as Scott mentioned. Also, tank and front fender is K.  500T is a twin cylinder.
More info here...
http://www.sohc4.net/cb550-model-guide/
« Reply #4 on: February 14, 2013, 07:33:47 PM »
Hell yes! Thank you guys for all the info. I already have all of the old stuf taken off the front end. I got some aftermarket slimmer for ears with the shims to clean it up a bit. When i get a chance I will post some more pics to help identify the bike. I ordered those seals after cross referencing the part numbers and they all check out. Thank you again for the help. Joining this forum was probably the best think I could have done!!!!  ;D
« Reply #5 on: February 14, 2013, 07:52:22 PM »
Oh and please get rid of that seat!  What type do you have in mind?
« Reply #6 on: February 14, 2013, 08:06:35 PM »
hahaha I have the stock seat for it...it had a really awesome Vetter windjammer on it too  :o What kind of what did I have in mind stev-o?
« Reply #7 on: February 14, 2013, 08:58:01 PM »
I prefer the stock seats or a cool cafe one if you are going that way. I have one of each!
« Reply #8 on: February 14, 2013, 09:26:09 PM »
Well I would love to make a nice cafe bike but I'm kinda penny pinchin right now, but I think this will turn out pretty good for a first try and who knows, maybe she'll be around for a few years and might just turn into something. :)
