Author Topic: New guy from Adelaide, Australia  (Read 1050 times)
Offline Brentm83
« on: February 17, 2013, 04:04:01 PM »
Hi all, been lurking for a bit and thought I'd best introduce myself.
I'm Brent, and am currently trying to piece together an old k2 750 honda from boxes.
This bike was my uncles, who crashed it, bought a few front end parts to replace, then wheeled it into his shed where it sat for the next 15-20 years.
About 10 years ago, my father grabbed the bike, got it running (barely), at which point I had my first ride (also barely!)
He then stripped most of the bike and boxed the parts to be refurbished or replaced.
Fast forward to today, I am attempting to piece those parts together and replace what is no good, it will not be an original resto, most likely cafe build.
The frame is '72, the motor '75, and I have no idea what the front end is, I hope someone can help me there.
The front rim has twin discs, but only one calliper is with the bike.
Offline Brentm83
Re: New guy from Adelaide, Australia
« Reply #1 on: February 17, 2013, 04:36:09 PM »
few pics
Offline Brentm83
« Reply #2 on: February 17, 2013, 04:42:46 PM »
took a minute to learn how to resize pics, here we go again
the forks are stamped with 341, im only really interested in what they are so i can order parts to rebuild them
« Reply #3 on: February 17, 2013, 09:01:58 PM »
Welcome Brent! Those look like K3-K6 lower fork legs.
Offline Brentm83
« Reply #4 on: February 17, 2013, 10:23:25 PM »
Thanks scottly!
I will document everything i do and possibly start a thread once my  wife has given birth. (34 weeks today)
I've built a few cars but this is my first bike build so ill be learning as i go.
« Reply #5 on: February 18, 2013, 01:20:32 AM »
gday brent how are you?youll have fun here and learn a lot aswell.
« Reply #6 on: February 18, 2013, 03:01:03 AM »
+1 to Dave's comments, welcome... ;)
Offline Brentm83
« Reply #7 on: January 29, 2014, 05:34:56 PM »
Time for a long overdue update... Im doing this from my phone so will likely start a new thread withpcs tonight.
Found that the engine was seized and was planning to rebuild the top end anyway, so out came the motor. Once i got it open, i found surface rust on cyl 3 holding it in place. A block of wood and wd40 fixed that right up.
Unfortunately for me, the rings on 3 were all stuck in the cyl grooves, plus one cracked ring. All the other cylinders were quite good.
I pulled cylinder 3 off to soak in atf in the hope of reusing it, which is when i discovered I have some Henry Abe 64mm pistons in there! All marked HA-64 TOHO CB810!
Now i really hope those rings come off, otherwise i may have 3 cylinders with rings for sale...
Offline 78 k550
« Reply #8 on: January 29, 2014, 07:37:36 PM »
Welcome,
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #9 on: January 30, 2014, 03:57:04 AM »
Welcome
