Author Topic: new issue on my 82 650  (Read 3516 times)
Offline rab1dwolf
Re: new issue on my 82 650
« Reply #25 on: July 24, 2006, 09:30:09 PM »
ive thought about it just havent done it.  gonna run up to the honda shop this week and get some cleaning supplies and plugs and see what i can accomplish.
1982 cb650sc nighthawk.  the work never stops.
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #26 on: July 24, 2006, 09:39:07 PM »
I recommend forking over the $$ for a few extra sets while you're there to set up for a plug chop.  Fresh plugs are always easier to read when you're trying to determine your throttle setting mixtures.
CB750K4
Offline rab1dwolf
« Reply #27 on: July 25, 2006, 01:20:43 AM »
yeah i figured id pick up a set and save my current ones as backups.
I had messed with my mix screws a bunch to try and get them perfect mix but had it set too lean for a few days and the plugs started to whiten a touch.  I put it back to what i had it set to before and then this all started happening shortly after....well heres hoping i geuss:)
Ebrandon
« Reply #28 on: July 25, 2006, 07:15:19 AM »
yeah i got an air filter but it just sits inside and theres three screws securing it in place....i think its time i looked and the micro fiche for that
edit1: ok just looked yeah im missing the stupid plactic cover never knew i was supposed to have one *sigh* geuss ill start looking for one of those now too....
edit 2: luckily just found one on ebay. put down a bid on it already, as for my jets i actually rebuilt the carbs a couple months ago with new jets and such so they are the right size.
Most of the time you'll want to leave that air cover off...
I actually bored out a hole in my air cover. It gets enough air flow, and still helps prevent too much junk from getting into the filter....
Offline byidesign
« Reply #29 on: July 25, 2006, 11:58:36 AM »
If you get a can of the "instant cold"
    and carry it with you , you can give it a shot
    under the seat, and you will know immediatly....
       the other is carry a couple spare plugs...
       when it quits plug one into each seperate coil
      lead, and crank for spark,it will tell you which side is going
           dead.......
              Bruce
82CB650SC,80CM400
Offline rab1dwolf
« Reply #30 on: July 25, 2006, 10:57:11 PM »
im going to go over the system and clean everything up and inspect all connections and replace the plugs with the other maintenace im doing this weekend.  I'm also going to replace part of my fuel line as its a bit crinked
